Problem advancing slide in Keynote
This is a discussion on Problem advancing slide in Keynote within the iWork Forum forums, part of the iPad App Store category; I have imported a PowerPoint presentation from my Wintel machine, and it doesn't always advance when I tap or swipe the screen. When it is ...
Results 1 to 5 of 5
    100996
    Sep 2011
    I have imported a PowerPoint presentation from my Wintel machine, and it doesn't always advance when I tap or swipe the screen. When it is stuck, it won't go backwards either. The screen response seems fine as I type this message, and the instructional presentation acted fine. I can only get to thet next slide by double tapping to edit mode and choosing the next slide on the left index bar. Thet presentation is about 7 MB in 14 slides. I've removed all the animation I can find in the presentation (did that before I importing it). Can't think of what else to try.
  2. #2
    69484
    Jun 2011
    26
    I had a similar problem when the .ppt file came from a Windows PC.
    If you can connect your iPad to an external monitor, when you run the slideshow, you will see green and red icons on the iPad screen. It's there to indicate when the next slide is ready to be used next.
    Nothing wrong, just loading times.
  3. #3
    62766
    2 times
    Jun 2011
    Washington state
    79
    Assuming you are using pictures to get a file that large with so few slides, you could try resizing the pics to the size they need to be before you place them in the slides. That should reduce the presentation file size and make the presentation work better.
    hth
    Beyond here, there be dragons.
  4. #4
    100996
    Sep 2011
    Thanks for the suggestions. I found that the main problem could be seen when I edited the animation of the slide show. I had tried to eliminate all animation, but something persisted. When I clicked on the edit animation button (in upper right of edit screen), some of my slides showed a golden triangle on their lower left corner. Touching such a slide would bring up a tag at right that said "None", meaning no animation associated with it; however, next to "None" was a Greater Than sign, which opens a window with two tabs. The Effects tab shows None, but the Options tab would show a "Start Transition" option with "After Previous Transition" instead of "On Tap". In addition, the Delay was set to long times, like 85 seconds. Making the delay 0, and starting after tap solved my problem.
  5. #5
    62766
    2 times
    Jun 2011
    Washington state
    79
    Glad you got it worked out.
Sponsors
  1. How do you inset audio file in slide in keynote?
    By paul.rene in forum iPad at Work
    Last Post: 03-24-2012, 09:09 AM
  2. PDF slide show .... sort of!!
    By jerliz in forum iPad General Discussions
    Last Post: 05-19-2011, 11:38 PM
  3. slide show or portfolio app
    By CMFox in forum iPad Help
    Last Post: 03-17-2011, 02:22 AM
  4. How Do You Turn Slide Show OFF?
    By pdmike in forum iPad General Discussions
    Last Post: 01-03-2011, 01:57 PM
  5. Slide sounds?
    By steve56 in forum iPad Hacking
    Last Post: 05-13-2010, 05:07 PM
advancing slides in keynote
delayed hyperlinks keynote
how to advance slides in keynote
i can't rearrange my keynote slides
keynote click for next slide
keynote first slide ends trouble
keynote how to advance past a slide animation
keynote how to advance slides in slide only view
keynote ipad how to next slide
keynote next slide without animation
keynote not changing slides during audio
keynote problem presentation ends after 1st slide advance
keynote slide won't advance
keynote slides won't advance
keynote transition wrong
keynote won't advance slides
keynote wont skip to next slide
slide show keynote problem display
stuck in presentation keynote ipad
why doesn't it go to the next slide keynote
