Numbers to Excel Issue
This is a discussion on Numbers to Excel Issue within the iWork Forum forums, part of the iPad App Store category; Hello all. I have encountered an issue with converting my numbers documents to excel. When I open the file in excel, a green triangle fills ...
Hello all. I have encountered an issue with converting my numbers documents to excel. When I open the file in excel, a green triangle fills the top left corner of the first row of cells. Excel says the number is saved as text. When I use pivot tables, a new data set appears from nowhere and I don't have a clue where it references from. Thanks!
08-25-2011 02:30 PM
Sorry for the post, I figured out a solution.
iPF Elite
Thats a relief. I wouldn't even know where to start. And then there's the fact that I don't' have Excel, making testing a just a bit difficult.
I wonder if the problem would show up in OpenOffice.
iPad Addict
Originally Posted by
daker
Hello Daker - you might want to explain your solution briefly; might help others w/ the same or a similar problem - just a courtesy to others. Thanks -
Yes, sorry. Excel was correct in saying that the number was saved as text. When I went back to my spreadsheet in Numbers and tapped the problematic cells, the keyboard popped up and the T was highlighted for which type of data to input in the cell (text, number, date, checkmark are the options). I had to select the number option and input the numbers that way. Excel didn't recognize the numbers input from the text option I guess. This was difficult to explain, so let me know if you could follow.
iPF Elite
Made sense to me. Thanks.
I just purchased numbers but it does not open excel file, i receive the message spreadsheet could not be imported. Can anyone help me aboy this? Thanks
iPF Elite
Did you use the standard .xls format when saving from Excel?
What method did you use to import the spreadsheet into Numbers?
Numbers may also have problems with advanced features in the Excel like pivot tables and scripting; though it should just tell you those features have been stripped and import anyway.
I used idisk but the problem is i have a excel file little complicated i guess that is the reason it is not recognize. My excell file has some macros. Do you think this might be the case?
iPF Elite
Even if Numbers imported the file, it would strip the macros. It only supports basic features. Here are a couple of reviews that may give you an idea of what Numbers and similar solutions will do. No iPad app has the same full feature set of a desktop applications. To be certain it is a problem with the file and not a problem with importing try a simpler spreadsheet and see what happens.
Compare iWorks, Office 2 HD, Documents to Go, QuickOffice by richsdams
http://www.ipadforums.net/new-member...31-hi-all.html
Office Apps Comparison by RedCoil (details and examples, very long)
http://www.ipadforums.net/iwork-foru...omparison.html
- You may not post replies
- You may not edit your posts
Forum Rules
By MikeV99 in forum iPad Apps
Last Post: 07-22-2011, 02:10 PM
By takenomorimonster in forum iPad Help
Last Post: 07-05-2011, 05:29 PM
By candirisk in forum iPad Help
Last Post: 06-22-2011, 12:27 AM
By Jaquin in forum iPad General Discussions
Last Post: 12-08-2010, 03:12 PM
By RAC in forum iPad General Discussions
Last Post: 10-20-2010, 01:46 PM
*.numbers file to excell
.numbers to excel
can numbers link to an excel file
can numbers on ipad open excel
convert excel to numbers ipad
converting numbers file to excel
excel on ipad problems
excel row problem on ipad
how to open a numbers spreadsheet in excel
how to open numbers documents in exel
how to open numbers file in excel
import apple numbers excel
numbers excel ipad problems
numbers ipad excel
numbers to excel
open .numbers in excel
open number files in excel
open numbers in excel
save numbers file as xls from ipad
