Need help with Numbers
This is a discussion on Need help with Numbers within the iWork Forum forums, part of the iPad App Store category; I imported an Excel spreadsheet that included charts. I was able the to change the data range in ons chart. When I started in the ...
Results 1 to 10 of 13
    65853
    Jun 2011
    44
    I imported an Excel spreadsheet that included charts. I was able the to change the data range in ons chart. When I started in the next I got some unwanted data accidentally selected. I have looked at the help section and done what it said but never did get a choice of any kind. According to help, delete is supposed to appear so the data can be deleted. I have been using it for about 2 months. I see that it was updated May 31. Since I did not have to delete a data range before the update, I have no idea if this could be the problem.
    Someone mentioned exporting a Numbers file to be edited in Excel. How do you do that? I don't dee anything, so far in the help section that addresses that
  2. #2
    96 times
    15,270
    Quote Originally Posted by sunny day View Post
    At the bottom of a Numbers spreadsheet there's a curly arrow that allows you to email the spreadsheet in .xls format. You could then edit it on your PC. If you're a MobileMe subscriber, you'll also see the option to save the spreadsheet to the MobileMe cloud storage iDisk.
  3. #3
    65853
    Jun 2011
    44
    Thanks. That may be the fastest way for me to edit my mistakes.
  4. #4
    65853
    Jun 2011
    44
    Just checked and there is no curly arrow. Had to select the wrench at the upper right, then share and print, then email. Then given choice of what format.
  5. #5
    96 times
    15,270
    I should have been clearer. Not when you're actually in the spreadsheet, but when you're in the My Document view. Bring the spreadsheet so that it's the highlighted one, but don't open it. Then you'll see the curly arrow at the bottom of the spreadsheet. Sorry I wasn't clearer...
  6. #6
    iPF Elite
    176 times
    Dayton, WA
    9,230
    @Tim, That's right, you're still running the older version. Come on, be brave and upgrade.
    @Sunny Day, Export is now done with the document open. Tap on the wrench icon and choose the Share and Print option. Tap to email, and you will get a choice of export formats, one of which will be Excel.
  7. #7
    iPF Elite
    176 times
    Dayton, WA
    9,230
    Also, now that I've really read your original post:
    To delete unwanted data ranges;
    Double tap on the chart. All data ranges should be highlighted in the table. Tap the bar above the column (or to the left of the rows) containing the data. It might take a couple tries to hit the right spot. Aim for the dot. You will get a Delete Series option in a popup menu.
  8. #8
    65853
    Jun 2011
    44
    Quote Originally Posted by twerppoet
    That's my problem, the delete series choice does not come up. I double tap the chart and all the data series show up with blue boxes around them with a blue dot at the lower right. I have tapped this dot, held the dot, sent nasty thoughts at the dot, and I can't get the delete choice to come up. Frustration. I have to be doing something wrong, or not doing something right, but I have no idea what it is.
  9. #9
    iPF Elite
    176 times
    Dayton, WA
    9,230
    Wrong dot. I meant the dot at the top of the series, the one that shows what color the data in the chart is. Tap on the bar above the series, or to it's left if you are doing rows. The dot is just a convenient target to help make sure you tap in that bar.
    See attachment.
    Attached Thumbnails Attached Thumbnails Need help with Numbers-numberschartseriesdelete.png
  10. #10
    65853
    Jun 2011
    44
    Ok, I see what you mean. I found it, but still have a problem. This spreadsheet is long, I am working about the 220th row. After I double tap I the chart and scroll to the top, touch the dot, and as soon as I touch anywhere on the screen the delete series disappears. Any ideas?
Sponsors
  1. Help with numbers!!!
    By RickH in forum iWork Forum
    Last Post: 11-02-2011, 09:53 PM
  2. Numbers app
    By robertmorgan480 in forum iPad Apps
    Last Post: 03-20-2011, 04:24 PM
  3. Numbers
    By jimdd in forum iPad Apps
    Last Post: 02-07-2011, 01:18 AM
  4. New to numbers
    By Blarto35 in forum iWork Forum
    Last Post: 10-17-2010, 10:59 PM
  5. Only certain numbers
    By poshpantspaddy in forum iWork Forum
    Last Post: 07-04-2010, 04:01 PM
change chart colors in numbers ipad
change colors chart ipad numbers
color chart numbers
delete row numbers ipad
edit chart colors numbers ios
how change color ipad numbers chart
how to change chart colors in ipad numbers
how to change colors with ipad numbers
how to change graf series colors in numbers in ios
how to change graph series colors in numbers for ipad
how to delete rows in numbers for ipad
how to get rid of graph lines in numbers app on ipad
inumbers navigation
ipad numbers app chart colors
ipad numbers customize chart colors
numbers bar graph colors
numbers for ipad change chart series color
numbers ipad delete cell data
numbers ipad how to edit colors chart
numbers iwork change chart data range
