Help with numbers!!!
This is a discussion on Help with numbers!!! within the iWork Forum forums, part of the iPad App Store category; I am putting together a spreadsheet using numbers on my very first ipad (2) EVER! I have been using Microsoft FOREVER (first time with a ...
Results 1 to 10 of 14
    47156
    Greenville SC
    I am putting together a spreadsheet using numbers on my very first ipad (2) EVER! I have been using Microsoft FOREVER (first time with a MAC of any kind). This one equation is KILLING ME. Here is what I am trying to do.
    I am a personal trainer and I track peoples weight. So, I have a column of cells that reflects the changes in their weight going from top to bottom. At the very bottom I have a cell that I want to show the "last number in the series of those weigh ins" i.e. each time I add a weight in an empty cell (of the progression) I want it to show up in that bottom cell. If you need a photo image I will be happy to send one. That's all. Very simple. The excel formula is using LOOKUP and a series of symbols and row/cell locations and works perfect. I feel like LOOKUP is what I want but what in the world do I use when all I have to work with is tabs that say "Search for" "search where" and "result-values". PLEASE help! I know there is a formula to do this. Thanks
    Rick
  2. #2
    iPF Elite
    176 times
    Dayton, WA
    9,230
    Banged my head against it for a while, but didn't get anywhere. I may try again later when my head stops hurting.
  3. #3
    iPF Elite
    176 times
    Dayton, WA
    9,230
    Ok, I still don't understand most of how this works, but the OS X version of Numbers has a weight tracking template that does what you want. I exported it to the iPad, and the formula still worked. If you look over the formula they use maybe you can tweak it to work on your spreadsheet.
    Here's a link to download the file: http://dl.dropbox.com/u/17742163/weight.numbers
  4. #4
    iPad Enthusiast!
    12114
    Aug 2010
    31
    But, to do what you asked, double tap on the cell into which you want to put the formula. A window will open, tap the "=" on the bar above the keys, then tap the "functions" button, then "reference" and you will see Lookup as a function you can use.
    Teach a man to fish, etc, etc, etc.
  5. #5
    iPF Elite
    176 times
    Dayton, WA
    9,230
    I'm pretty sure the OP knows the function is there. They just couldn't decipher the use instructions. Neither could I. I spent quite a bit of time trying to use the LOOKUP function, but could not make it work as suggested. The formula that works in the Pages example uses different functions in combination with an IF statement. I think I understand it, but haven't looked up all the functions used to make sure.
  6. #6
    iPad Enthusiast!
    12114
    Aug 2010
    31
    Perhaps he did know the function is there, but he said, 'all I have to work with is tabs that say "Search for" "search where" and "result-values".' To me that statement shows that he didn't realize a double-tap on the target cell opens up a greater set of choices. If you tap the cell once, that's what you get, you have to tap twice to get to the functions. But in either case, he now has options. It's all good!
  7. #7
    iPF Elite
    176 times
    Dayton, WA
    9,230
    I thought the same as you, until I looked up the LOOKUP function and realized what he was calling tabs were actualy the names of the parameters for the function, something I probably would not have noticed if I had not got curious and tried to set up a table to use it.
    As you say, no harm, no foul.
  8. #8
    iPad Enthusiast!
    12114
    Aug 2010
    31
    Yep, you are right! I got it backwards. My apologies for questioning your inerrant intuition!
  9. #9
    iPF Elite
    176 times
    Dayton, WA
    9,230
    More like stubborn and pedantic. No apologies necessary.
  10. #10
    18360
    Oct 2010
    Denver
    Large Spreadsheet test request
    I am looking for someone to test a large (about 12mb) Excel spreadsheet on the Ipad 2 that was too large for the original Ipad. I was considering Docs to Go but really do not care which app.
Sponsors
  1. Numbers app
    By robertmorgan480 in forum iPad Apps
    Last Post: 03-20-2011, 04:24 PM
  2. Numbers
    By jimdd in forum iPad Apps
    Last Post: 02-07-2011, 01:18 AM
  3. New to numbers
    By Blarto35 in forum iWork Forum
    Last Post: 10-17-2010, 10:59 PM
  4. Numbers
    By Sincere11105 in forum iWork Forum
    Last Post: 08-21-2010, 08:06 AM
  5. Only certain numbers
    By poshpantspaddy in forum iWork Forum
    Last Post: 07-04-2010, 04:01 PM
apple numbers if function
example of numbers vlookup on ipad
help with mac numbers
how do i email only one page of a spreadsheet from numbers on my ipad?
how to insert column in numbers on ipad
how to use filters in ipad numbers
how to use numbers on ipad
how to use numbers on ipad 2
ipad numbers help
ipad numbers help lookup function
ipad numbers iwork tutorial
ipad numbers tutorial
mac numbers help
numbers for ipad not working
numbers for ipad uses
numbers ipad examples
numbers ipad help
numbers ipad tutorial
numbers tutorial ipad
personal trainer ipad numbers
