Help with numbers!!!
This is a discussion on Help with numbers!!! within the iWork Forum forums, part of the iPad App Store category; I have numbers please feel free to message me with how I can help...
Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    65419
    Jun 2011
    29
  3. #12
    18360
    Oct 2010
    Denver
    5
    Large spreadsheet
    Quote Originally Posted by drich290195 View Post
    Can I email the file to you?
  4. #13
    65419
    Jun 2011
    29
    Quote Originally Posted by Scavenger123
    Yeah sure I'll send u my email
  5. #14
    91457
    Aug 2011
    College Place, WA
    Quote Originally Posted by RickH View Post
    I am putting together a spreadsheet using numbers on my very first ipad (2) EVER! I have been using Microsoft FOREVER (first time with a MAC of any kind). This one equation is KILLING ME. Here is what I am trying to do.
    I am a personal trainer and I track peoples weight. So, I have a column of cells that reflects the changes in their weight going from top to bottom. At the very bottom I have a cell that I want to show the "last number in the series of those weigh ins" i.e. each time I add a weight in an empty cell (of the progression) I want it to show up in that bottom cell. If you need a photo image I will be happy to send one. That's all. Very simple. The excel formula is using LOOKUP and a series of symbols and row/cell locations and works perfect. I feel like LOOKUP is what I want but what in the world do I use when all I have to work with is tabs that say "Search for" "search where" and "result-values". PLEASE help! I know there is a formula to do this. Thanks
    Rick
    I have exactly the same need (pretty much the same reason, making a diet tracking spreadsheet). After hours of research here is what worked for me. (B2:B64 is the range in the column.)
    =INDEX (B2:B64, COUNTA(B2:B64))
    Index & CountA are both functions. when usuing the iPad it is a bit difficult to figure out because you can not just type in the formula, apple holds your hand. When you put in the Index funtion you get all the "bubbles" to replace. touch on the ones you need to replace and in this instance you have to delete a few optional ones that are not needed.
    (range) is the cell range you are looking at, delete (row-index) and (column-index) and the commas in between them. touch (area-index) and replace with COUNTA(B2:B64) {you have to use your finger to select the range, you can not just type it in}
    Thats it. Worked like a charm. This cell then gives you the last entry in the range.
    Hope this helps someone - it sure took me long enough to figure it out.
    Farnorth.
  1. Numbers app
    By robertmorgan480 in forum iPad Apps
    Last Post: 03-20-2011, 04:24 PM
  2. Numbers
    By jimdd in forum iPad Apps
    Last Post: 02-07-2011, 01:18 AM
  3. New to numbers
    By Blarto35 in forum iWork Forum
    Last Post: 10-17-2010, 10:59 PM
  4. Numbers
    By Sincere11105 in forum iWork Forum
    Last Post: 08-21-2010, 08:06 AM
  5. Only certain numbers
    By poshpantspaddy in forum iWork Forum
    Last Post: 07-04-2010, 04:01 PM
help with numbers
how to dl kill 2 in ipad
how to insert column in numbers on ipad
ipad numbers function reference
ipad numbers tutorial formula
mac numbers lookup function
mac numbers templates weight tracker
numb ers tutorial for i-pad
numbers app for ipad tutorial
numbers ipad tutorial
numbers tutorial ipad
vlookup tutorial mac numbers
