Numbers help with formula running down a page
This is a discussion on Numbers help with formula running down a page within the iWork Forum forums, part of the iPad App Store category; Hi guys, I havent fully searched the forum for this as wasnt entirely sure how to explain it, but i will try! I am creating ...
Results 1 to 4 of 4
    27718
    Hi guys,
    I am creating a spreadsheet to track who has completed a task most recently and down the left most collumn i want to have a date, (for example 02nd Jan 2011), which then increases by exactly one week each line you drop down.
    So for example, A1 would show 02/01/2011 and B1 would show 09/01/2011.
    How do i write the formula for this, and can I then fill down the page so that it follows this sequence for the entire year?
    I hope i have provided a detailed enough explanation!
    Thanks in advance for your help...
    BFM
  2. #2
    iPad Enthusiast!
    18699
    Oct 2010
    Oklahoma
    33
    Quote Originally Posted by BoredFatMan View Post
    Hi guys,
    BFM
    I'm not sure about your formula (yet) but, I am sure about the concept of doing these kinds of things on a Mac or PC using all the comfort they bring and then exporting the file (I use iDisk) to the Ipad for use. Any formulas can be copied or easily modified as needed.
    I do a lot of Excel work with some pretty complicated formulas and most of the time, I get way to frustrated trying to originate a sheet on the Ipad due to input limitations (even using my BT keyboard). Virtually all of my sheet entrys are done on the Ipad and I find the above works best for me.
    Hope that helps.
    Mike
  3. #3
    iPad Junkie!
    15345
    2 times
    Sep 2010
    New York City
    134
    Hi guys,
    BFM
    I would fill in the first three dates in the respective cells
    Select that range of filled in cells
    Tap on the range to bring up the context menu and select fill
    The rein will be outlined in a heavy gold border that I think has some thin black lines either inside or outside of the border
    Anyway, tap and hold on the lower edge of the gold border and drag it down as far as you need to or to the bottom og the page
    If you need to scroll the page up you will have to tap the bottom of the extended range and select fill again
    This usually works for any regular series of numbers and possibly days of the week and months of the year
    A seed hidden in the heart of an apple is an orchard invisible.
    Welsh proverb
    Typo assist by iPad
  4. #4
    53617
    May 2011
    jax, fl
    date formula
    Sorry for bumping this, but the formula was never posted that does this. If A1 has a date and you want A2 to be 1 week later, then the formula is simply:
    =a1+7
    When you add rows to your table, fill the equation down.
    Jason
Sponsors
  1. Printing or copy and paste a magazine page or a page froma book
    By cyben in forum iPad General Discussions
    Last Post: 12-27-2010, 08:32 AM
  2. Numbers - running MS excel functions
    By Jaquin in forum iPad General Discussions
    Last Post: 12-08-2010, 03:12 PM
  3. Formula One Car Crash Video
    By Gabi in forum Off-Topic
    Last Post: 09-21-2010, 02:04 AM
  4. Running Banner/Splash Page after login
    By fitzswi1 in forum iPad General Discussions
    Last Post: 07-22-2010, 11:45 AM
copy down in numbers
copy down in numbers ipad app
copy formula down in numbers
copy formula in numbers
fill down formulas in numbers
fill down in pages
fill equations in mac numbers
how is numbers running on ipad
how to copy a formula in inumbers
how to copy a formula in numbers
how to drag formulas in numbers for ipad
ipad numbers fill down
ipad numbers formula input
ipad numbers paste increase
ipad pages drag formula down
iphone numbers copy equation
iwork numbers fill down formula
numbers copy function
numbers fill formula
numbers for ipad help how to copy and paste formulas
