Numbers problem....
This is a discussion on Numbers problem.... within the iWork Forum forums, part of the iPad App Store category; Wheni duplicate a spreadsheet I've created, I need to delete all the data (on the duplicate) WITHOUT deleting the format as well. Is this possible?...
Results 1 to 2 of 2
    255422
    Nov 2012
    Numbers problem....
    Is this possible?
    1518 times
    Walla Walla, WA
    15,429
    The only thing I've found to work is to call up the cell editor by double tapping the cell, then sue the backspace/delete key to remove the contents and tap done.
    The good news is that you can move between cells by tapping on each one without leaving the cell editor. Also, if you just tap the backspace key without first tapping on the text field it will delete everything; text and data with one tap, formulas with two taps.
  1. Numbers problem!!!
    By ochickey in forum iWork Forum
    Last Post: 11-04-2012, 05:09 PM
  2. numbers and excel problem
    By telemicus in forum iPad General Discussions
    Last Post: 08-23-2012, 05:13 PM
  3. Problem with the Numbers App
    By renafromab in forum iPad Help
    Last Post: 06-06-2012, 05:09 PM
  4. Replies: 3
    Last Post: 03-17-2012, 07:44 AM
  5. IPad Numbers Problem
    By JWhitTX in forum iPad Help
    Last Post: 10-27-2011, 06:29 PM
numbers.app read all text in field
