How to delete iTunes from PC running XP?
This is a discussion on How to delete iTunes from PC running XP? within the iTunes Forum forums, part of the Apple iPad Discussions category; Ok. I tried to delete iTunes using add remove programs in Windows XP and I get a fatal error. I had a disk crash a ...
Results 1 to 2 of 2
    278210
    Feb 2013
    Kuala Lumpur
    50
    Ok. I tried to delete iTunes using add remove programs in Windows XP and I get a fatal error. I had a disk crash a while back, and I think I moved the iTunes folder to another disk. Now I can't delete iTunes.
    My question ... is it possible to just delete tho folder manually, then open up regedit and manually searh for iTunes and delete every iTunes entry I find in the registry? Is there a better way?
    (If that works, then I delete the rest "Bonjour", "Apple Installer" etc etc using add remove from control panel)
    Ok. I managed to solve my problem. I had to remap the disk drive and now I can update to latest iTunes.
    310044
    Feb 2014
    india
    Actualy it is not posible I think there is big virus in your compute or sofware you have to install new window
  1. Replies: 10
    Last Post: 01-07-2013, 08:24 PM
  2. How to delete a course from itunes university?
    By parfect2 in forum iPad General Discussions
    Last Post: 08-29-2011, 06:40 PM
  3. Replies: 0
    Last Post: 06-14-2011, 05:30 PM
  4. iTunes running in Ubuntu!
    By DrHouse in forum iPad General Discussions
    Last Post: 05-07-2011, 09:24 PM
  5. how do you delete movies fro iTunes?
    By nateccnn in forum iPad General Discussions
    Last Post: 01-01-2011, 09:51 AM
