Power consumption
This is a discussion on Power consumption within the iPad OS forums, part of the Apple iPad Discussions category; I notice my battery life is substantially shorter since I upgraded to IOS 6. Anybody notice that also?...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    143360
    Dec 2011
    Third rock from the Sun
    28
    Power consumption
    110082
    34 times
    Oct 2011
    Upstate, NY
    819
    Mine seems to be about the same. Has anything else changed on your iPad settings wise or whatever? Just curious.
    32GB Wifi iPad 2 / OS 6.0
    244228
    Sep 2012
    15
    I also have the same similar
    177945
    Mar 2012
    10
    I've had the same problem as well, but more so with my iPhone 4 than iPad. It doesn't come anywhere close to how it did prior to iOS 6. Woke up the other day at 7:30 and unplugged the iPhone at 100%. Sent 3 texts and put the iPhone down. Went back to bed ( I was sick) and 4 hours later the battery was at 23%????? What the heck? Hadn't used it at all! Is there some new settings in iOS 6 I should be looking at or changing? Brightness is under half.... Most location services turned off..... Not thrilled right now. Hope there is something I'm missing. ( iPad just went from 83% to 77% while typing this!?!? Maybe it is affecting my iPad 3 as well)
    49720
    277 times
    SC
    5,365
    Quote Originally Posted by Mustashi View Post
    Something is definitely wrong here. There must be something in there. Are you using GPS or BT? I don't have such a problem on either my 4S or 2012 iPad.
    177945
    Mar 2012
    10
    Not that I know of....location services are off ( except find my iPhone) and bt is off. May try a restore in iTunes as was suggested in another thread. Maybe my iPhone 4 is the problem vs IOS 6.
    48854
    75 times
    Weston WI
    854
    Do you have mail set to download manually? Any notifications? Just run through all settings to be sure nothing new has been turned on.
    177945
    Mar 2012
    10
    Yes email is set to manual....I do have some notifications on, but I get very few of those a day. I've been looking for some strange settings but nothing yet. I'm probably missing something really obvious! I let the battery drain empty and did a full overnight charge. Battery life has been somewhat better since. I'm at 10% battery with 2 hours 46 minute usage right now after a full overnight charge.....very frustrating.
    143360
    Dec 2011
    28
    Nothing changed nor anything new. It was the same iPad 3 with the same applications except it used to last all day with one charge (I am a heavy user from surfing web to doing my work related activities) but since the IOS upgrade, my battery is drained by mid-day and have to recharge in order for it to last till I retire at night.
    I don't think it is normal. I myself is an engineer and consider myself very knowledgeable in this kind of stuff but blaming adding new applications will render the power to only last half of what it used to be is inexcusable to me. I love my iPad no less than anybody on this board but if Apple indeed screw up, I expect them to fix it ASAP.
    189505
    Apr 2012
    5
    I have noticed worse battery as well. I notice brightness is much brighter. I lower it but it seems to stay to bright anyway meaning its gets brighter if I close the cover and reopen...
  1. List application storage consumption
    By shackleton in forum iPad OS
    Last Post: 01-29-2012, 03:38 PM
  2. Power from USB
    By Gtatler in forum iPad 2 Forum
    Last Post: 01-26-2012, 05:54 PM
  3. Power Consumption
    By ADubin in forum iPad 2 Forum
    Last Post: 10-08-2011, 07:10 PM
  4. Replies: 42
    Last Post: 05-19-2011, 10:30 PM
  5. Apps for view my iPad memory consumption by type ?
    By paulyeo11 in forum iPad General Discussions
    Last Post: 01-26-2011, 07:58 AM
apple os 6 power consumption
apple os 6 power usage
ios 6 power consumption
ios 6 power usage
ios6 power consumption
ios6.1 power
ipad 3 power consumption when off
ipad 4 power consumption
ipad power consumption
iphone 6.0 power settings
iphone power consumption forums
power options on ipad os6
