iMessage Not Working. Help!
This is a discussion on iMessage Not Working. Help! within the iPad OS forums, part of the Apple iPad Discussions category; Anyone having a problem with iMessage? So far everything else seems ok. I have tried several times to log in and eventually get a error ...
Results 1 to 10 of 19
Like Tree3Likes
Thread: iMessage Not Working. Help!
    91929
    Aug 2011
    20
    Anyone having a problem with iMessage? So far everything else seems ok. I have tried several times to log in and eventually get a error message saying PLEASE CHECK YOUR NETWORK CONNECTION AND TRY AGAIN LATER. There is no problem with my network connection I've been online every time on several websites even as I tried to connect with iMessage. Anyone out there with some help
  2. #2
    96 times
    15,270
    I have moved your post to the iOS section, where I think it will receive better attention.
  3. #3
    108710
    2 times
    Oct 2011
    5
    Quote Originally Posted by Lanas19
    Sorry if this sounds dumb but have you switched iMessage on in settings and set your apple ID in the "receive at" field?
    Tim SPRACKLEN and Ni2080 like this.
  4. #4
    91929
    Aug 2011
    20
    Quote Originally Posted by kilo6
    Thanks I was able to get that going. But I still can't get iCloud to hook up to mail. I turn on mail in the iCloud settings, then the screen appears asking to create a me.com account. I hit yes, but in the info and then I keep getting this message " THERE'S A PROBLEM TURNING ON YOUR EMAIL. TRY AGAIN LATER. I tried at least 25 times and the same thing happens???
    Sent from my iPad using iPF ***Lana***
  5. #5
    129652
    Nov 2011
    Alabama
    I am having the same problem with iMessage but do not see the "receive at" field. Where is it located? Thanks.
  6. #6
    129652
    Nov 2011
    Alabama
    I am having the same problem with iMessage but do not see the "receive at" field. Where is it located? Thanks. As a matter of fact, the "receive at" block does not show up at all.
  7. #7
    124306
    Nov 2011
    11
    Quote Originally Posted by usmcwa
    Go to setting and click message . It will show option to turn on iMessage and at the bottom, type in your apple ID in the "received at"
  8. #8
    78763
    Jul 2011
    Not so sure if any one else has this problem but I can't register any other mail to receive iMessage apart from the apple ID email add. It keeps giving verification error.
  9. #9
    139821
    Dec 2011
    Chicago, il
    I have iMessage turned on and have apple Id email addy entered on iPad2 and ipod and for some reason my daughters iPod and my ipad2 keep telling us the contact is not registered with iMessage when we try to send one another a message?.. The send button won't allow us to click on it to send..
  10. #10
    iPF Elite
    176 times
    Dayton, WA
    9,228
    The send button problem is usually because you've entered your text in the subject field instead of the message field. You can skip the subject field, but never the message itself. This is very easy to do, since the two fields are right on top of each other and only faintly labeled.
Sponsors
  1. IPAD IMESSAGE text messaging not working
    By Shinereed in forum iPad Help
    Last Post: 01-26-2012, 05:05 PM
  2. IMessage
    By lepagek in forum iPad General Discussions
    Last Post: 11-06-2011, 12:01 AM
  3. iMessage
    By iParga in forum iPad OS
    Last Post: 11-02-2011, 11:39 AM
  4. iMessage on ios 5
    By iHellmy in forum iPad OS
    Last Post: 10-20-2011, 12:15 PM
  5. iMessage vs BBM ?
    By DonnaDuke in forum iPad Help
    Last Post: 10-19-2011, 05:26 AM
imessage check network connection
imessage connection error
imessage error
imessage ipad not working
imessage is not working
imessage network connection
imessage network connection error
imessage network error
imessage not connecting
imessage not delivered
imessage not delivered error
imessage not logging in
imessage not working
imessage not working ipad
imessage not working on ipad
imessage on ipad not working
imessages not working
ipad imessage not working
problem with imessage
why is imessage not working
