iMessage Not Working. Help!
This is a discussion on iMessage Not Working. Help! within the iPad OS forums, part of the Apple iPad Discussions category; Originally Posted by twerppoet The send button problem is usually because you've entered your text in the subject field instead of the message field. You ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Like Tree3Likes
Thread: iMessage Not Working. Help!
  1. #11
    139821
    Dec 2011
    Chicago, il
    The send button problem is usually because you've entered your text in the subject field instead of the message field. You can skip the subject field, but never the message itself. This is very easy to do, since the two fields are right on top of each other and only faintly labeled.
    I turned the subject field off in the settings.. Prior to attempting to do message. So we only have the body line to type in.
    I had assumed the send button wasn't highlighted because it's saying the contact isn't registered with iMessage even though we've both filled in all fields and can access and downloads from the apps program ..as a way to confirm our apple Id is valid.
    Appreciate the help any other suggestions to try?
    E.
  2. #12
    iPF Elite
    176 times
    Dayton, WA
    9,228
    Quote Originally Posted by DreamRyder View Post
    E.
    Oh well, it was worth mentioning it, just in case; though as I read back though the thread (I was in a hurry the first time) I see it was already covered.
    The only other things I can think of you've probably also tried.
    In Settings > Messages > Receive At, make sure the email address you are trying to use is there, and correct. You can try removing and adding it again. (you can only remove the first address if you have a second one) You could also try alternate email addresses, if you have any. In my experience it will reject email addresses if they won't work; for instance it rejects my yahoo address and gives me a an error message.
    It probably wouldn't hurt to make sure the Caller ID matches the email you intent to receive messages at. It tends to confuse things if Messages sends messages back as someone other than who you sent it to.
    That's all I've got. Good luck.
  3. #13
    142675
    Dec 2011
    N.Ireland
    I'm having the same problem, every time I try to activate it with my apple id it brings up the network message. Same for FaceTime. Really frustrating now.
  4. #14
    iPF Elite
    176 times
    Dayton, WA
    9,228
    Saw a survey yesterday that said iOS activations were 12 to 15 time higher over Christmas day than normal (in US and UK). The servers could still be getting hammered by all the new iOS devices being initialized (and in some cases upgraded). Keep trying.
  5. #15
    142919
    Dec 2011
    Hi there I am having problems synching my Calendar between my iPhone and ipad2 it was fine before I went over to ios5 I have tried everEything iknow(very little)resetting both machines ensuring everything matches etc but just can't get it to work?
  6. #16
    iPF Elite
    176 times
    Dayton, WA
    9,228
    What method are you using to sync the calendars?
    iTunes
    iCloud
    GMail
    or some other service.
  7. #17
    148552
    Jan 2012
    I am having a problem with iMessage on iPad 2? I have tried several times to log in and eventually get a error message saying PLEASE CHECK YOUR NETWORK CONNECTION AND TRY AGAIN LATER. There is no problem with my network connection. It used to work and I don't know what changed. Anyone out there with some help please.
  8. #18
    148552
    Jan 2012
    iTunes
    iCloud
    GMail
    iCloud
  9. #19
    182870
    Mar 2012
    List of 10 fixes for iMessages issues
    Here's a list of 10 fixes for iMessage not working issues:
    http://www.sinatranetwork.com/wordpr...not-delivered/
    twerppoet likes this.
Sponsors
  1. IPAD IMESSAGE text messaging not working
    By Shinereed in forum iPad Help
    Last Post: 01-26-2012, 05:05 PM
  2. IMessage
    By lepagek in forum iPad General Discussions
    Last Post: 11-06-2011, 12:01 AM
  3. iMessage
    By iParga in forum iPad OS
    Last Post: 11-02-2011, 11:39 AM
  4. iMessage on ios 5
    By iHellmy in forum iPad OS
    Last Post: 10-20-2011, 12:15 PM
  5. iMessage vs BBM ?
    By DonnaDuke in forum iPad Help
    Last Post: 10-19-2011, 05:26 AM
imessage check network connection
imessage connection error
imessage error
imessage ipad not working
imessage is not working
imessage network connection
imessage network connection error
imessage network error
imessage not connecting
imessage not delivered
imessage not delivered error
imessage not logging in
imessage not working
imessage not working ipad
imessage not working on ipad
imessage on ipad not working
imessages not working
ipad imessage not working
problem with imessage
why is imessage not working
