BlogPress problem
This is a discussion on BlogPress problem within the iPad OS forums, part of the Apple iPad Discussions category; Hello all, after updating my BlogPress app does not open. I am in the middle of my travel blog. Please help ! Sent from my ...
Results 1 to 10 of 10
    66268
    Jun 2011
    Wisconsin
    81
    BlogPress problem
    Please help !
    61094
    6 times
    Jun 2011
    271
    First of all turn your iPad off completely and then restart it. If that doesn't work check the app store for an upgrade to the app you are using.
    66268
    Jun 2011
    Wisconsin
    81
    Quote Originally Posted by K1W1
    Hi, thanks for the prompt reply. Unfortunately there is no update and shutting off and re starting didn't work.
    66268
    Jun 2011
    Wisconsin
    81
    Quote Originally Posted by charlyee
    I emailed the developer and got a prompt reply beck saying that the update is in the App Store for approval. I hope it doesn't take too long since I am using it on a daily basis for my trip.
    115583
    Oct 2011
    Omaha, NE
    Quote Originally Posted by charlyee View Post
    Please help !
    Did you ever get it to work? I just updated to IO5, wrote a blog post, and as soon as I saved a draft, it started crashing and I cants get in. I emailed developed but no reply yet
    66268
    Jun 2011
    Wisconsin
    81
    Quote Originally Posted by Wislanscraft View Post
    I un installed and re installed and it was working fine until yesterday. I had same problem as you and un installed and re installed it many times. I finally decided that I would just post to the web however much I had instead of saving as draft and that seems to be holding up, maybe you can try that?
    Please post what the developer said, this app is not playing nice with iOS 5.
    115583
    Oct 2011
    Omaha, NE
    Thanks! I uninstalled and reinstalled and was able to update my blog, although I had to start from scratch on the post I had almost finished. For safety's sake, I published and *then* proofread it. I'll let you know what developer says as soon as he/she responds...
    66268
    Jun 2011
    Wisconsin
    81
    Well it crashed again, fortunately I had only made two changes and tried to save it. I see everyone complaining about it in the App Store, and are waiting for an update that is awaiting approval.
    Have you looked into any alternatives?
    66268
    Jun 2011
    Wisconsin
    81
    I need to find an alternative to BlogPress, which has been crashing since the iOS5 update and the developer is MIA.
    Can someone please recommend an app that will work with Blogger, I need to find one quick.
    Thanks much.
    158785
    Jan 2012
    Country WA
    6
    I'm having trouble adding my blog details to BlogPress. When I go to enter my info, I get a blank screen.
  1. Wi-fi problem
    By UchihaIPAD in forum iPad Help
    Last Post: 09-27-2011, 10:31 PM
  2. Replies: 20
    Last Post: 09-07-2011, 07:59 AM
  3. Help re BlogPress App
    By Cajame in forum iPad Apps
    Last Post: 08-20-2011, 06:48 AM
  4. Trouble with WordPress and BlogPress for iPad
    By owlsheadbiz in forum iPad Apps
    Last Post: 08-02-2011, 08:08 PM
  5. Garageband problem or ipad2 touchscreen problem?
    By Summy73 in forum iPad Apps
    Last Post: 06-02-2011, 05:35 PM
blogpress app crashes
blogpress app not working
blogpress crash
blogpress ios 5
blogpress ipad
blogpress ipad crash
blogpress ipad help
blogpress ipad problems
blogpress issues
blogpress not working
blogpress problems
problems with blogpress
