home sharing problem
This is a discussion on home sharing problem within the iPad OS forums, part of the Apple iPad Discussions category; Hi, there might be a silly fix for this that I'm not seeing , I can not seem to connect my ipad 2 to home ...
Results 1 to 6 of 6
    39125
    plymouth uk
    59
    Hi,
    there might be a silly fix for this that I'm not seeing , I can not seem to connect my ipad 2 to home sharing it did randomly work the other day but why I don't know as I was not doing anything special,it will connect every time to my ipad 1 without problems.Any idea why I'm having these problems or can you only use one apple device with this feature, obviously I'm not trying to use them at the same time.I'm up to date with ipad and itunes software
    thanks in advance
    116 times
    15,249
    There's some advice here...
    How to Set up Home Sharing in iTunes - wikiHow
    iPad Guru
    30446
    11 times
    3,197
    Considering HomeSharing works from iPad 1, it can't be an incorrect iTunes setting. And on the iPad, there is only one option to set:
    Enter your Apple ID under Settings->iPod->Home Sharing
    Why HomeSharing would not work, is a bit of a mystery. HomeSharing isn't even limited to one device, you can stream two different movies onto two iPads from the same PC and given a sufficiently fast wireless router, there won't be any lag.
    Perhaps restart i2 and see, whether that makes any difference?
    39125
    plymouth uk
    59
    hi
    iv tried restarting pc, restarting home sharing and restarting ipad plus putting the id back on again ect in various combinations, it randomly worked again today but now its not again iv got a fast wifi router so its not that.
    Banned
    12904
    34 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Quote Originally Posted by samch
    hi
    I know I had to pair my iPad with iTunes and it works every time now.
    39125
    plymouth uk
    59
    A late reply to this but I found if I restart my pc it works for a few hours but then stops and nothing but restarting again will solve it,I don't know what's causing it but iv found that iTunes is very temperamental at times, iv uninstalled and reinstalled it but it's still the same,it's a shame cos sharing is a good feature of iTunes for all my iOS devices but there seems to be a problem with my pc and bonjour which is the software iTunes uses for sharing .
  1. Home Sharing Video Library (SLOW)
    By Da of 2 in forum iPad General Discussions
    Last Post: 09-20-2011, 04:07 PM
  2. Home sharing- videos won't play
    By Isyss in forum iPad Help
    Last Post: 03-26-2011, 09:48 AM
  3. Home sharing
    By Mike_73 in forum iPad OS
    Last Post: 03-17-2011, 09:35 AM
  4. Home sharing issue with music videos
    By Amay77 in forum iPad Help
    Last Post: 01-02-2011, 01:43 AM
  5. Home sharing...more than one iTunes account ?
    By Dr.Gee in forum iPad General Discussions
    Last Post: 01-01-2011, 06:10 PM
home sharing ipad problem
how o fix home sharing on my ipad
ipad 2 won't connect to home sharing
ipad can't connect to home sharing
ipad cannot connect to home sharing
ipad home sharing issues
ipad home sharing not working
ipad home sharing problem
ipad won't connect to home sharing
ipad wont connect to home sharing
why cant i connect home sharing on my ipad?
why isnt home sharing working ipad 2
