OS 4.2 upgrade problem
This is a discussion on OS 4.2 upgrade problem within the iPad OS forums, part of the Apple iPad Discussions category; Hi, I'm new to this forum, and would like to say hi. Beside saying hi I would to say how much I love the Ipad. ...
Results 1 to 8 of 8
    23036
    Dec 2010
    I was very excited about the upgrade to 4.2 but have not been able to get this done. Every time it backs up it gets stuck on part 1 of 4, 3 quarters of the way through. I have left this on for over 24 hours and nothing happens. I tried synching it first but the same thing happens so I have not been able to upgrade. Is there something I am missing? I know I have a lot of pictures and some apps on this but is should synch and update. help!!!
    17419
    2 times
    Oct 2010
    Texas
    646
    Sounds like you are having trouble syncing not updating. To update go the first page and click update. It will then update the os to 4.2. If it's snagging when trying to sync more than likely it's a corrupted file. Just don't have it sync whatever its getting stuck on then add it back a bit at a time until you find what movie/book..ect is making it stick.
    Everything is Bigger in TEXAS!!
    iPad 16GB WiFi
    iPhone4 32GB
    Be sure and check out iphone4forum.net! For anything iPhone..
    Me over on the other side...
    23036
    Dec 2010
    Thanks for the reply, I appreciate it. I've tried to just update it without synching, itunes looks like it's updating but it never updates the ipad, it usually throws me back to backing up the ipad and never finishes, I've tried this a lot of times. I was hoping there was a way to update it without going through the backing up part but it's not allowing me. :-(
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    I have not used this particular program, but many people have had success using a program called "Backoff" which allows you to bypass the backup process while syncing. The program can be found at -- BackOff Speeds Up iTunes Sync for iPhone, iPod Touch and iPad
    Please note that this does not fix the issue you are having with an app that is causing the problem, it is only a workaround.
    23036
    Dec 2010
    Thanks, I will give it a try tonight.
    23036
    Dec 2010
    Looks like the Backoff program worked, evrything was going smoothly then the Ipad and Itunes froze on me. I eventually had to call Apple Tech support, not wait, very nice. I had to restore back to factory settings, this eventually worked sometime when I was sleeping last night. The Ipad is up and running but it looks like not all of the Apps are back on the Ipad but are in Itunes on different pages, any clue how to get them on the Ipad?
    Thanks for all of the help, very much appreciated.
    24843
    Dec 2010
    Las Vegas, NV
    5
    I cannot get past the processing message. I get a message the network connection is lost. I have tried to just download the update but the same thing happens. I have tried to download the update several times the past week.
    I am new here and am new to the Ipad
    24843
    Dec 2010
    Las Vegas, NV
    5
    Smile 4.2 download
    I finally got the update installed in my Ipad. I disabled Kaspersky security and proceeded with the download. Everything worked fine. Problem solved.
    Paul
  1. Replies: 3
    Last Post: 12-04-2010, 12:40 PM
  2. 4.2 upgrade no upgrade?
    By Anton in forum iPad Help
    Last Post: 11-25-2010, 01:09 AM
  3. upgrade
    By steve1204 in forum iPad General Discussions
    Last Post: 11-24-2010, 06:17 PM
  4. Problem with the photo app after upgrade
    By Hansg in forum iPad Help
    Last Post: 07-25-2010, 04:25 PM
  5. USB upgrade -- Anyone tried it?
    By Pingles in forum iPad General Discussions
    Last Post: 06-04-2010, 09:37 AM
havong trouble updating ipad cart os
ipad os problems
ipad update 4.2 download
ipad upgrade problem
ipad upgrade problems
os 6 update for ipad not working
problem updating ipad to os6
problems with ipad os6 update
problems with ipad upgrade
promblem in updating ipad
upgrade ipad problems
upgrading ipad 2 os4 to os5
