Camera Connection Kit
This is a discussion on Camera Connection Kit within the iPad OS forums, part of the Apple iPad Discussions category; Hi, has anyone had problems with the camera connection kit? First set did not work and I returned them and the new ones don't work ...
Results 1 to 5 of 5
    21262
    Nov 2010
    south carolina
    Hi,
    has anyone had problems with the camera connection kit? First set did not work and I returned them and the new ones don't work either. Get the message that they are not compatible and to dismiss. Called Apple and get a run around. Person on phone did not know anything about problem and gave another number that never seems to answer. Thanks for any help.
    15357
    Sep 2010
    Germany
    102
    Works fine for me.
    What did you do when this message showed up?
    Did you connect a camera or an SD-card?
    An SD-card must be formatted in a camera first to work.
    It needs the DCIM-folder. If this folder exists, the iPad will look for pictures in this folder.
    If not, it will show the error you had.
    21262
    Nov 2010
    south carolina
    Thanks Mark,
    my camera uses CF card so formatted card in computer. Still get the same error. Thanks for your help
    6760
    Jun 2010
    Atlanta, GA USA
    92
    Quote Originally Posted by jackpg View Post
    Thanks Mark,
    My cameras - all various Canon EOS models, now EOS 7D - all recommended formatting the CF card in the camera for best results.
    21262
    Nov 2010
    south carolina
    Format Card
    Dutch, I was referring to the SD card that I formatted in the computer. I have no camera to format it. I then copied pictures to it and they work fine between computers, but not IPad. Thanks for your input.
  1. Camera Connection Kit
    By Al Rogers in forum iPad Help
    Last Post: 10-13-2010, 04:26 PM
  2. I got the Camera Connection Kit!
    By Bluesjam in forum iPad General Discussions
    Last Post: 08-10-2010, 11:51 PM
  3. Replies: 3
  4. Camera Connection Kit with Panasonic LX3 Digital Camera
    By Atwell in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-23-2010, 08:35 AM
  5. Camera Connection Kit Where Are You?
    By ipadfanatic in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-22-2010, 09:13 AM
are canon cameras compatible with ipad
are canon cameras compatible with the i-pad camera connection kit?
cameras compatible with ipad camera connection kit
car
iusb
