Problems with camera connection kit !
This is a discussion on Problems with camera connection kit ! within the iPad OS forums, part of the Apple iPad Discussions category; Originally Posted by thomaswhite@mvcs.org Looks like one of my teachers figured it out. Here's what he found: The photos app now will only import pictures ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    17891
    Oct 2010
    Canada
    66
    Arrow
    Quote Originally Posted by thomaswhite@mvcs.org View Post
    The photos app now will only import pictures that are named like a picture off the camera. So, if you're using a camera, no problem, but if you're trying to load in pictures that are coming from another source on the SD card, you have to make them look like pictures that came straight from a camera. In the past, we had to "trick" the photos app by creating a folder. Now, we have to trick the photos app by renaming them; for example DSC_0001.jpg.
    Very interesting
    thomaswhite@mvcs.org !
    Does that mean I don't have to create a DCIM dir if I rename my files as you explained ... DSC_00002.jpg ?
    Or do I have to do both ?
    Thanks to you and your teacher.
    Andy Loba
  3. #12
    5965
    7 times
    Jun 2010
    311
    As the CCK costs so much here, I was very reluctant to buy it given the problems reported on this forum and elsewhere, but, being such an Apple addict, I did! It works fine for me using the SD card dock.
    I really think that Apple changed the dynamics when they realized people were using it as a USB. But for just photos taken on camera and then transferring them to ipad, it seems to work.
  4. #13
    21983
    Nov 2010
    Henderson, Nv
    12
    A friend just emailed me regarding the difficulty with using the camera/SD card kit with the new iOS.
    Here's a quote from his email....
    "Apple's iOS 4.2 upgrade has prevented data being read from some USB devices because the fondle slab puts out five times less power than before.
    The iPad has a camera connection kit enabling pictures on SD cards in digital cameras to be transferred to the iPad. This works well with the previous iPAD O/S, iOS 3, but that has 100ma going out to the USB device whereas iOS 4.2 only dribbles out a weak 20ma, not enough for many USB-connect devices.
    An Apple support discussion forum thread covers the issue."
    He went on to say, "
    Using a powered USB hub apparently works as a fix."
  5. #14
    16070
    Sep 2010
    L.A.
    177
    thank you Steve Jobs!!! now we have to go through all that just to get access to our stuff...
  6. #15
    iPad Enthusiast!
    17606
    Oct 2010
    29
    before i updated the ipad it worked with a USB cable and card reader, now it says not enough power.
    I don't use a camera with an sd card so i need to restore the old OS are figure out the work around.
    Lowjiber1 any clues about how the powered hub fits in the picture (no pun intended)?
    Plug the powered hub into the connector and the card reader into the hub,, that seems the most logical
    gosh, just more stuff to drag around when traveling ugh.
    Just tested it and that will work, plug the powered hub into the connector and then the card reader into the hub.
    thanks for the info.
  7. #16
    5965
    7 times
    Jun 2010
    311
    I seem to be lucky...one of my cameras uses a larger card but I can just insert it into a card reader, then into the iPad, which reads the photos just fine.
  8. #17
    12328
    Aug 2010
    Markdale, Ontario
    571
    Well this sucks. I FINALLY found a local store that sells the CCK and then I found that the new iOS neuters it.
    Thank you Apple....ya morons.
    I never give up. Snideness and rudeness of any sort WILL be returned in kind.
  9. #18
    47421
    Westchester, NY
    Annoying, but fixable
    Good news!
    So as has been previously reported all pictures must reside in the directory DCIM on the memory card. Additionally, the file name must be 8 characters long; No more, and no less. So as an example "PIC00001.jpg" and "PIC12345.jpg" are both proper file names. However "Picture001.jpg" is not and the iPad will not recognize it.
    Renaming files can be a pain so on my PC I downloaded a utility called
    "Batch Rename .EXE" from Download.com. It worked very well and solved the 8 charater problem for me.
    I recommend moving all the original files on you memory card to a directory other than DCIM and letting the Batch Rename .EXE utility both rename and move the newly named files to the DCIM directory.
    Works like a charm! Good luck!
  10. #19
    47480
    Thanks, that was what i looking for... tztztz
  11. #20
    19138
    5 times
    Oct 2010
    Frederick, MD
    327
    Quote Originally Posted by WIllyB
    Good news!
    Excellent report! Thanks for the info.
    Tom
    EMP-Susceptible - with an iMac, 15" MacBook Pro/Retina, MacBook Air 11", iPod touch 2, 4, and iPad 2.
  1. Email Server Connection Problems
    By fletchflynn in forum iPad Help
    Last Post: 08-16-2011, 03:24 PM
  2. Replies: 3
  3. Camera Connection Kit with Panasonic LX3 Digital Camera
    By Atwell in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-23-2010, 08:35 AM
  4. WLAN Connection problems
    By Asdbla in forum iPad Help
    Last Post: 07-03-2010, 07:42 AM
  5. connection kit problems
    By samsberr in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-14-2010, 05:32 PM
apple camera connection kit problems
apple camera connection kit problems ios6
apple ipad camera connection kit problems
ipad camera adapter problems
ipad camera connection kit troubleshooting
ipad camera connection problems
ipad connection kit problem
ipad4 will not recodnize camera adapter
trouble shoot sd card will not download on ipad
troubleshoot ipad camera connection
troubleshoot ipad sd card connection kit
