Problem with lock screen
This is a discussion on Problem with lock screen within the iPad OS forums, part of the Apple iPad Discussions category; None seen this? The power button single press isn't working, but the button itself clearly is I.e. A long press works and asks if I ...
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By willerz2
  • 1 Post By byrnea
Thread: Problem with lock screen
    304353
    Oct 2013
    None seen this?
    The power button single press isn't working, but the button itself clearly is I.e. A long press works and asks if I want to shut down. Also, the lock screen function in assistive touch isn't working, but a long press on that gives me the option to switch off. I have a Smart Cover and the magnet on that doesn't lock the screen any more.
    What the hell is going on?
    iPad Addict
    167823
    187 times
    Feb 2012
    New York
    1,136
    Which iPad and/or iOS device combination are we referring to.
    Victoria022 likes this.
    iPhone 4S White 16 GB iOS 7.1 ||iPad Mini 16GB (WiFi) iOS 7.0.4 Evasi0n7||AppleTV2 iOS 5.2 Seas0nPass
    Please read and abide by the forum rules
    iPhone Forums Moderator
    271154
    6 times
    Jan 2013
    United States
    77
    A pic of the issue you were talking about would surely help.
    304353
    Oct 2013
    I have ipad 2 and iOS 7.
    I am not sure if the problem relates to the iOS 7 upgrade. It might.
    It's clear though, as neither the soft or hardware options for lock screen are working, it must be an OS issue, right?
    I did read about it on other forum but there was no reply, but others are having the issue.
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Quote Originally Posted by byrnea View Post
    None seen this?
    Hello & welcome to the forum! Does the same problem exist w/ the power button when 'assistive touch' is deactivated? Also, I would suggest removing the smart cover and then 'Resetting' the iPad, if not already done (directions quoted below) - if effective, then replace the cover to see if the magnet now locks the screen. If not helpful, then please post back here - good luck! Dave
    Reset - press & hold the 'Power' and 'Home' buttons simultaneously until the Apple logo appears - this may take a longer time, so have patience; the iPad will 're-boot' - NOTE that none of these maneuvers will alter your apps, files, or settings.
    213285
    268 times
    Jun 2012
    St. Louis, USA
    957
    I suspect the original Smart Covers are starting to fail now. A friend relies on one to put his iPad to sleep, and last week his battery drained to zero overnight.
    304353
    Oct 2013
    sorry i have been away but this problem is still there. it has nothing to do with assistive touch or Smart Cover. the function to power into standby simply is not there, either via short press power button (though long press does give me full power off), via Smart Cover or other magnet, or via assistive touch. this is strange
    thanks
    304353
    Oct 2013
    sorry, i properly read the advice from Giradman and it has fixed my problem. Switched off the lock screen option and powered off the iPad. Thank you
    Mickey330 likes this.
    13576
    1447 times
    Aug 2010
    Western NY state (USA)
    11,053
    Glad to hear it's sorted. Thanks for telling us (and anyone looking for a solution to the same problem) that it's fixed. Always good to hear back, especially the success stories.
  1. Replies: 1
    Last Post: 05-10-2013, 11:36 AM
  2. Having lock screen/ power down screen glitch.
    By J.Patrick in forum iPad 4 Forum
    Last Post: 12-18-2012, 12:36 AM
  3. Replies: 4
    Last Post: 01-14-2012, 12:35 PM
  4. JB Home screen / Lock screen screenshots
    By vitalion in forum iPad Hacking
    Last Post: 07-08-2011, 04:15 AM
  5. post a screen shot of your home/lock screen.
    By Joker in forum iPad General Discussions
    Last Post: 08-27-2010, 08:28 PM
assistive touch settings on ipad 2 os7 locked screen
