Hello, 1st thread. Need help with playing backing tracks.
This is a discussion on Hello, 1st thread. Need help with playing backing tracks. within the iPad for Musicians forums, part of the Apple iPad Discussions category; Hi, I am looking to change the format I use for playing backing tracks through my PA system. I am currently using mini discs and ...
Results 1 to 6 of 6
    263745
    Dec 2012
    Durham
    Hi,
    I am currently using mini discs and have been told that I may be able to use an Ipad using an Alesis docking station.
    If this is so I would need to be able to record some existing backing tracks onto a software programme in order to change their format, as well as importing MP3's and tracks bought from Itunes.
    If this is possible what would I need to buy?
    198647
    49 times
    May 2012
    Kansas
    3,399
    Hello and welcome to the forum!
    I hope you are able to find a resolution to your issue...
    263745
    Dec 2012
    Durham
    1st thread.
    Thanks smalltowngirl13. Have been browsing and found a couple of interesting links.
    48665
    479 times
    Brisbane, Australia
    19,173
    Hi Mel and welcome to the Forum!
    I've moved your thread to our ipad for Musicians Section where you will receive a better response.
    Tutorial on creating posts on the Forum
    Creating Posts and Starting New Threads - How To
    iOS5 Tips and Tricks
    Easy pictorial shortcuts & Helpful places. - For People new to the iPad.
    iPad 2 64gb 3G
    285824
    Mar 2013
    MA, USA
    Hi
    I am also interested in using my iPad (4th Gen) for backing tracks. In my case, for years, I have been using a pc with Cakewalk (MIDI sequencer) connected to a Roland Sound Canvas, which in turn connected to my PA.
    I ended up uploading my analog tracks to my MacBook, doing some editing as far as volume using Audacity and saving them as MP3's. Then I transferred them to a song player program on my iPad called SongBook+ (BauM software out of Germany). I connect the iPad to the PA with a USB configuration. Works great.
    I'll stop here in case you found a solution that works for you. But, if you haven't, send a reply and I'll fill you in on the details as far as the gear used to connect all of this together so that it works.
    Pete
    214946
    2 times
    Jun 2012
    120
    I'm not sure if you are looking to change the audio file format or do something like audio editing. One of the free apps called Music Studio, I believe lets you import MP3s and assign it as a track for editing. I think there are many programs or apps that can convert the audio format if that is what you are trying to do.
  1. iPad to Play Backing Tracks in Live Performance
    By mmwarner in forum iPad 2 Forum
    Last Post: 04-20-2013, 02:52 AM
  2. A gig that lets you bring your own backing tracks.
    By Magnetic1 in forum iPad for Musicians
    Last Post: 11-25-2012, 09:40 PM
  3. App for playing multiple tracks simultaneously?
    By jesperhs in forum iPad for Musicians
    Last Post: 08-11-2012, 05:57 PM
  4. Playing tracks one at a time
    By Philobrien in forum iPad Help
    Last Post: 06-16-2012, 11:33 PM
  5. Backing tracks
    By donsch1 in forum iPad Help
    Last Post: 04-27-2011, 03:27 AM
backing track
backing tracks for ipad
using ipad to play backing tracks
