Which way is better to do MIDI on iPAD?
This is a discussion on Which way is better to do MIDI on iPAD? within the iPad for Musicians forums, part of the Apple iPad Discussions category; I could get a yamaha portable keyboard with MIDI ports or a you rock guitar. I believe the iRIG midi works with you rock guitar ...
Results 1 to 5 of 5
    214946
    2 times
    Jun 2012
    120
    I believe the iRIG midi works with you rock guitar without the camera kit.
    And I don't know if a MIDI to USB works with the iPad via the camera kit.
    Question is do all iPad music apps like GarageBand, MusicStudio, SampleTank, etc...
    support both of these devices or have they made the choice for me?
    I heard about core MIDI but I don't know what all that means for yamaha and you rock guitar sending regular MIDI.
    I found a description in an app that indicated the app is compatible with core midi supporting midi keyboard. So then not all midi keyboards support core midi???
    183639
    2 times
    Mar 2012
    United States, Virginia
    31
    I would check out the website for each one of those apps. Also, Music Studio has a forum here that you can get support from. The camera connection method only works on some apps, but that site I linked you to also has a list of supported devices and MIDI hardware.
    Hope that helps
    214946
    2 times
    Jun 2012
    120
    Thanks.
    I was hoping someone already did the leg work.
    I kind of prefer the USB if it would work, because I'm optimistically thinking iPad would support multiple midi devices at once some day.
    183639
    2 times
    Mar 2012
    31
    Quote Originally Posted by Magnetic1
    Thanks.
    No problem! I have done a little bit of research on the hook ups because I plan on buying some hardware. I want to use the keyboards in the music department of where I attend school to make some MIDI tunes on Music Studio, but I'll do that when I have some extra spending cash
    214946
    2 times
    Jun 2012
    120
    I hear you. Midi gear can add up real quick.
  1. Midi sequencer for Ipad
    By Mattjof in forum iPad for Musicians
    Last Post: 11-12-2012, 12:27 AM
  2. Import midi to ipad
    By prdarby in forum iPad for Musicians
    Last Post: 09-09-2012, 10:34 PM
  3. Ipad and midi
    By calpol86 in forum iPad 2 Forum
    Last Post: 06-12-2012, 08:14 AM
  4. Ipad as midi controler
    By brecht050 in forum iPad General Discussions
    Last Post: 02-05-2012, 10:12 AM
  5. Demo of iPad Garageband using USB Midi
    By RTomStudios in forum User News Submissions
    Last Post: 04-27-2011, 08:53 AM
