ipad 3 latency and other questions...
This is a discussion on ipad 3 latency and other questions... within the iPad for Musicians forums, part of the Apple iPad Discussions category; Hi guys i`m a proffesional solo singer/guitarist.I want to replace my guitar effects unit and laptop/ minidisk player (that i use for backing tracks) with ...
Results 1 to 3 of 3
    251408
    Oct 2012
    tenerife
    with just my ipad 3. What apps are other members using ie amplitude or stompbox for instance...Can you load and play backing tracks as well..?
    I tried using Guitarig on my laptop but was very dissapointed with the latency. I`ve been looking at the apogee jam interface. Before i part
    with my hard earned cash what do other members use or recommend. If latency is a problem, as i wil be playing live, i`ll give it a miss and
    stick with what i`ve got...Many thanx in advance.
    252732
    Oct 2012
    Indianapolis, IN USA
    5
    Check driver and buffer settings - this may help with the latency issue.
    272619
    Jan 2013
    Las Vegas
    10
    First, the apogee – excellent little device. What I love most about it is the reduction in hiss and 60 cycle hum when compared to any of the headphone jack interfaces, which is only an issue if you play with distortion, but the difference is HUGE. The only drawback is that it uses the same port as the charging cable, so you have to be sure you have enough charge for the length of your set. Second, latency. On an iPad 2, using JamUp XT, there is little to no discernible latency even with very heavy use of effects. I was very disappointed with the sound of GuitarRig with my equipment, and I did notice an annoying amount of latency, but others seem to love it. As a side note, always make sure that all other apps are killed and not just "closed" by pressing the start button when you use an iDevice with amp/effects apps. Anything running in the background can reduce performance. Hope that helps.
    — "Expert" is the title that society awards someone who is recurrently shocked and surprised by what the rest of us saw coming —
  1. Replies: 2
    Last Post: 09-27-2012, 07:47 PM
  2. Ipad Touchscreen Lag/Latency
    By shaftpolls in forum iPad General Discussions
    Last Post: 08-23-2012, 04:08 AM
  3. Considering iPad; had a few questions?
    By FoxCruiser in forum iPad General Discussions
    Last Post: 07-17-2012, 02:02 PM
  4. Latency on music instrument app
    By queenesther235 in forum New Member Introductions - Site Assistance
    Last Post: 02-20-2012, 07:45 PM
  5. Just two questions on my new IPad.
    By NLAlston in forum iPad General Discussions
    Last Post: 02-24-2011, 03:17 PM
apogee jam guitarig
