What is the best device for recording and producing music?
This is a discussion on What is the best device for recording and producing music? within the iPad for Musicians forums, part of the Apple iPad Discussions category; Hi everybody. I'm trying to decide whether to buy an iPad mini or a Mac. I'd like to record my songs and possibly produce them ...
Results 1 to 10 of 15
Like Tree3Likes
Thread: What is the best device for recording and producing music?
    292711
    Jun 2013
    13
    Hi everybody. I'm trying to decide whether to buy an iPad mini or a Mac. I'd like to record my songs and possibly produce them using Apple software. Any suggestions? Also, do any of you Voiceover users know how to successfully use iRig recorder?
    1546 times
    Walla Walla, WA
    15,471
    The iPad has three advantages over a Mac: portability, the touch user interface (not to be underestimated), and price. Though there is some overlap on the last. In all other areas (computer power, available peripherals, and powerful apps) a Mac is the more capable device for just about everything, including music creation.
    So the real question is if the iPad will be enough for what you want, or if you need/want and can afford a more powerful solution.
    Both amateurs and professionals have created some amazing things using nothing but iPhones and/or iPads, but I don't think any of them would argue that a more powerful setup couldn't have done more and better.
    Of course, if money is not a major obstacle, at least in the long term, you can start with an iPad and add a Mac and more gear as you grow into it. The iPad wont' stop being useful just because you get a Mac later. I've seen a few articles about musicians using then together to produce great music.
    These are just my general thoughts on the subject. I'm not a musician myself, and have no significant experience with the recording or production of music.
    Gabriel1 and anilnc like this.
    196908
    4 times
    Apr 2012
    Upstate NY
    52
    Buy the newest and largest capacity iPad you can afford, a couple of mics of your liking and order this https://www.alesis.com/iomix
    You'll be good to go!
    293556
    Jun 2013
    Quote Originally Posted by Splawkin19 View Post
    An iPad is great for soft synths and the DM-1 is a great beat box, but a Mac would be a better choice for a number of reasons:
    1. Logic. Apple's DAW is amazing. I've used it for years and it is an industry standard.
    2. USB 3.0. You'll probably want an external HD as multitrack audio sessions get extremely large. 8 tracks of audio at a minute length could easily weigh in at 100mb.
    3. Multiple Monitor support. It is very convenient to have dual monitors, one for tracking and the other for your mixer/vst/au plugins
    287965
    Apr 2013
    India
    22
    Both iPad and Mac are the products from Apple. In terms of display, power consumption, and other features iPad is considered as more advanced. Mac almost looks the same with iPad but it can never replace iPad. Moreover Mac is costlier than iPad. If you do not have a computer or a personal system, both the devices are useful for you. You can use dropbox app in iPad if you want to save your records.
    286369
    Apr 2013
    India
    19
    If u want to make music with apple software then I prefer Mac for its multitrack DAW like logic and many others, not to mention its power also. For iPad version apple at present provide only Garage Band which can record maximum of 8 tracks. It actually has maximum 8 tracks available including midi instruments tracks. If that's enough for you the. You can go for ipad. Ipad mini has less CPU power compared to ipad full which limits the multitrack features and latency in other iOS DAWs.
    294100
    Jun 2013
    New York
    28
    all the advices are good enough to go for except the price issue is the biggest cause for many .. so is there any second best solution rather than the brand Apple for a quality music offering ..
    286369
    Apr 2013
    India
    19
    All powerful pc are good enough for music production. The processor must be powerful good ram above 8gb ddr3, pci express video card. And a good hard disk minimum 7200rpm or preferred to go with solid state drives. Then finally the OS, where apple is Horse power, stability and speed for creativity flow, not to mention its memory management. Ofcourse you need a ASIO compatible sound card. Sound card vary according to each requirements and budgets.
    Even though its spec might look higher and the price lower than the apple product, still apple OS can battle the field very well.
    Don't think I'm apple user, no. I only use iPad Mini. I use my win 764bit for my production. But have experienced the differences on both systems. I can't afford apple (mac pro / imac) at the moment.
    Moderator
    235421
    619 times
    Aug 2012
    Adelaide, South Australia
    3,671
    Quote Originally Posted by anilnc View Post
    There was a mistake in my above comment but don't know how to edit or delete it. There are no options to do that in tapatalk app.
    I was telling finally apple OS which makes most powerful and stable for a quality production.
    Hi, anilnc, it's fairly easy in Tapatalk.
    Just tap the arrow in the box up top.
    Which gives you the choice to open in Safari website mode. Tap on that.
    And you will have the means of editing your post.
    Regards, Andrew
    anilnc likes this.
    Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Check out the rules~ http://www.ipadforums.net/forum-rule...ease-read.html
    iPad3 64gig black, much unused PC Win 8.1 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
    286369
    Apr 2013
    India
    19
    Hey thanks a lot Andrews, its really helpful.
    Cheers.
  1. All About Music And Recording
    By ipfuser55 in forum iPad Apps
    Last Post: 11-10-2012, 07:13 AM
  2. Music production help (recording app to app)
    By 24karrotts in forum iPad General Discussions
    Last Post: 07-18-2012, 07:14 PM
  3. Recording video while playing music
    By kennymartin164 in forum iPad 2 Forum
    Last Post: 03-10-2012, 07:35 AM
  4. best Music production/ recording apps
    By rezilent in forum iPad Apps
    Last Post: 10-27-2011, 12:09 PM
  5. All About Music And Recording
    By ipfuser55 in forum iPad 2 Forum
    Last Post: 05-14-2011, 01:34 PM
best devices for producing music
best ipad music recording peripherals 2013
best recording devices for ipad 2013
using ipad mini for recording music
