Help needed connecting a USB keyboard to 4th gen iPad (no sounds in Garageband)
This is a discussion on Help needed connecting a USB keyboard to 4th gen iPad (no sounds in Garageband) within the iPad for Musicians forums, part of the Apple iPad Discussions category; Hello all, I am trying to connect an M-Audio Oxygen 88 USB MIDI controller to a 4th Gen iPad but no sounds on key input.. ...
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Magnetic1
Thread: Help needed connecting a USB keyboard to 4th gen iPad (no sounds in Garageband)
    284150
    Mar 2013
    CT and NYC
    11
    Hello all,
    I am trying to connect an M-Audio Oxygen 88 USB MIDI controller to a 4th Gen iPad but no sounds on key input.. I am new to the iPad and I am connecting the keyboard as follows:
    Keyboard > powered USB hub > USB cable > lightning camera connection kit > 4th Gen ipad
    The keyboard lights up normally just as it would if it was connected to a computer, but no sounds or change in graphics on the iPad.
    (note: If I connect directly to the iPad, or disconnect the power from the hub I get an error about needing too much power). Do I need to set anything in GB on the iPad, or should it be straight forward from the start?
    Any ideas??
    -Thanks
    214946
    3 times
    Jun 2012
    156
    Avid keystudio with 49 keys seems to work with the 8 pin or lightning dock and SampleTank Free app. M-Audio Oxygen 88 may not be supported, I don't know for sure.
    F1Fanatic likes this.
    284150
    Mar 2013
    CT and NYC
    11
    I appreciate the response.. After a little fiddling in GarageBand, I was able to get it to work. Thanks! Any good virtual instruments for the iPad that I should try?
    214946
    3 times
    Jun 2012
    156
    So many to choose from in sampltank.
    I like the saxophone and oboe.
    But the recent free version no longer has oboe.
    Either way you can demo all of the sounds through their arpeggio feature.
    Arpeggios are broken chords, but I like to think of them as a stream of patterns.
    Afterall how can you quantify time delay effects.
  1. Camera Connection Kit and Garageband Help needed.
    By southseaisland in forum iPad 2 Forum
    Last Post: 07-20-2012, 02:16 PM
  2. No sounds when using keyboard
    By Rhinocharge1 in forum iPad 2 Forum
    Last Post: 06-04-2012, 01:59 AM
  3. Keyboard sounds - iPAD2 @ iOS5
    By Darkpath in forum iPad Help
    Last Post: 10-24-2011, 06:21 AM
  4. Help on connecting wired/bluetooth keyboard to my iPad
    By weedguru in forum iPad Hacking
    Last Post: 08-18-2011, 04:29 AM
  5. Keyboard Sounds on Ipad
    By ddewaal in forum iPad Help
    Last Post: 08-14-2011, 06:22 PM
how to connect m-audio keyboard to ipad 4th generation
ipad 4 lightning midi
lightning adaptor
m-audio oxygen no sound garageband
