Xlr microphones
This is a discussion on Xlr microphones within the iPad for Musicians forums, part of the Apple iPad Discussions category; Originally Posted by Blastingas10 Buying a mic is something I'm really afraid of. I don't wanna spend 50 dollars on a mic and have it ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Xlr microphones
  1. #11
    49720
    277 times
    SC
    5,365
    Quote Originally Posted by Blastingas10 View Post
    Buying a mic is something I'm really afraid of. I don't wanna spend 50 dollars on a mic and have it sound as bad as the ipad mic. I guess that's why I should make sure and get it somewhere that had a good return policy.
    I bought it from Amazon and to be honest, I should have sent it back (and they would have let me)...but I got distracted on something or other. This review, copied from Amazon, seems to pinpoint my issue:
    2 of 2 people found the following review helpful
    Pretty good starter mike, January 2, 2011
    By
    movingwordsandimages
    This review is from: Shure PG58-XLR Cardioid Dynamic Vocal Microphone with XLR-to-XLR Cable (Electronics)
    I used this mike for a really long while, to practice vocals at home for a spoken word and music project I was doing for a couple years. It's a Shure so it's good! But when you upgrade eventually to, say, the legendary SM58 or any of the Beta models, you will notice a SIGNIFICANT boost in power... Consider these other options if you're looking to record or perform for a live audience. Still, the PG58 is definitely great as an intro mike. And probably the best for the price!
    BTW, the reason I mentioned this in the first place was for the XLR issue, not this mic. If I had to do it over again, I think I would try the SM58 as the Archangel is suggesting.
    Also, I'm still not 100% sure I'm getting the most out of this mic yet.
  3. #12
    276851
    Feb 2013
    13
    I'm really looking for something under 100 dollars, but I guess if you have two mics, one for 50 and one for 100, it'd be worth just another 50 dollars for something good.
  4. #13
    276184
    Jan 2013
    Alberta
    9
    Not sure, but isn't the SM58 primarily a vocal mic? I think the SM57 is more the one to have for mic'ing an acoustic guitar. Anyway, wherever you buy gear, check to see if the retailer has a 30-day no quibble return policy. Most of the majors do.
  5. #14
    196908
    4 times
    Apr 2012
    Upstate NY
    51
    I use the SM57 as well to record guitar and drums. It's a good mic.
    If you know anybody that works at your local Guitar Center, ask them to buy one for you.
    They get a decent discount
  6. #15
    278908
    Feb 2013
    Minnesota
    I was going through the same deal when I got my iPad last year, wanted to plug in a mic as well. Sad to say not too many USB mics sound all that good for the sub $100 price range... I ended up demoing a Apogee MiC at a store near me and fell in love. Big solid sound and a really nicely built mic and you don't even need a Camera connection kit to use it! Which made me happy. It was $200 but I'd say it sounds better than a lot of the other choices. I've also heard good thing about the Blue Mics Spark Digital. Thats my two cents.
  7. #16
    47445
    10
    Camera connector kit + Griffin iMic + XLR to phono adapter will let you hook up any regular dynamic mic.
  8. #17
    283692
    Mar 2013
    Australia
    8
    Quote Originally Posted by ging View Post
    Ging is spot-on. The SM57 is a great all-rounder mic and you can use it for vocals, too (Moby did his entire first album using only an SM57). But the SM58 is a famous, industry-standard vocal mic.
  9. #18
    289046
    Apr 2013
    Bath UK
    8
    Not advertising for anybody, but Sweetwater reps would be able to answer your questions. They're really great.
  1. Headset Microphones for two wearers - how to?
    By SianG in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 11-12-2012, 04:25 AM
  2. Using my camera kit to connect my blu microphones bluebird mic is so easy
    By rezilent in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-09-2011, 11:33 AM
  3. Replies: 1
    Last Post: 12-09-2010, 05:34 AM
