help! just 90% - battery problem in my Mini... should I claim the warranty?
This is a discussion on help! just 90% - battery problem in my Mini... should I claim the warranty? within the iPad Mini Forum forums, part of the Apple iPad Discussions category; Howdy, I've noticed a peculiar thing. I charge my Ipad everyday because I use it extensivelly. Recently, when I've left my Ipad plugged in, the ...
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By KevinJS
Thread: help! just 90% - battery problem in my Mini... should I claim the warranty?
    281476
    Feb 2013
    44
    Howdy,
    I've noticed a peculiar thing. I charge my Ipad everyday because I use it extensivelly. Recently, when I've left my Ipad plugged in, the battery would charge to 90% only and after turning the Ipad of and restarting it, it would show 94%. Then, plugging the cable again doesn't change anything. The battery level remains at 94%. However, if I plug the charger to a different socket the battery starts charging itself again... till 100%.
    What should I do? I think there's a malfunction. My Mini is almost new... 2 months of usage.
    Can you offer any advice? I'm upset because of this whole matter...
    Thank you
    85546
    578 times
    Aug 2011
    Edmonton AB Canada
    9,851
    You're battery needs calibrating. Let it run down until the iPad turns itself off. Then charge it overnight. It should charge to 100%. You need to do this about once a month, according to Apple. I've found that calibration is not necessary anything like as often as that.
    wildmangk likes this.
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
    281476
    Feb 2013
    44
    Quote Originally Posted by KevinJS View Post
    Kevin, thank you for your reply. I did exactly what you told me. I just woke up and... The battery's level is 94% again What should I do now?
    85546
    578 times
    Aug 2011
    Edmonton AB Canada
    9,851
    Time to head for the Genius Bar. Tell them you've done a recalibration cycle, which hasn't worked. They may replace the iPad, or they may have other suggestions.
    I'm curious to know why it charges fully on the second attempt. That still has me thinking "calibration".
    281476
    Feb 2013
    44
    Thanks Kevin.
    Any advice on how I should backup my data before I give them my ipad? I have no idea about it. Will I lose all the apps I paid for?
    290703
    May 2013
    Oregon
    18
    You wont lose the apps you paid for. Just make sure when you get the replacement to sign in with the same user id and youll have the purchased apps ready for download. I speak from experience.
    Sent from my iPad Mini using Tapatalk
    85546
    578 times
    Aug 2011
    Edmonton AB Canada
    9,851
    Backup to your PC/Mac using iTunes.
    You will not lose any apps, so long as you use the same AppleID. Once you have bought them, they are yours.
    When you get your new iPad, set it up using the backup of the old one, and everything should be in place.
    1148
    Mar 2010
    142
    A similar thing happens on mine where it charges to 96% and then gets stuck. But when I take the charger out of the iPad some 20 minutes later and put it back in straightaway, it jumps to 100%. So its really charging even though it appears to get stuck. However if I leave the charger in very long time it eventually gets to 100% without any intervention.So if it appears to get stuck in the 90s, mostly likely it is still charging. After a while, take the charger out of the ipad and then put it back in and you might see it showing a full charge.
    214946
    3 times
    Jun 2012
    156
    Anyone consider maybe it's the charger.
    A charger most likely has a voltage regulator and a transformer. If the voltage from the socket is different for what ever reason, then the input voltage may not meet the charger requirement to produce the proper output voltage.
    I'm not saying this is likely because Apple stuff is pretty much the top of the line.
    295825
    Jul 2013
    In my case I found out that my iPad3 only did charge til 80% was because of the cord.
    I think maybe it was broke inside. A new cord solved my charging problem.
  1. iPad Mini Won't Show Battery Usage
    By ayufebiany in forum iPad Mini Forum
    Last Post: 05-03-2013, 02:42 PM
  2. a huge concern about my Mini's battery
    By mesmerized in forum iPad Mini Forum
    Last Post: 02-27-2013, 11:07 PM
  3. Will I be able to claim warranty for my iPad ?
    By Pook in forum iPad 3 Forum
    Last Post: 10-30-2012, 04:19 AM
  4. Unheard the Warranty Problem of iPad 2 in India!!!
    By Vicharerajesh in forum New Member Introductions - Site Assistance
    Last Post: 06-23-2012, 07:43 PM
how to solve ipad mini can only charge till 90%
ipad mini 90
ipad mini 90%
ipad mini 90% battery
ipad mini charge 90%
ipad mini charge till 90 %
ipad mini charge until 90
ipad mini stop charging at 90%
