Ipad mini problem :(
This is a discussion on Ipad mini problem :( within the iPad Mini Forum forums, part of the Apple iPad Discussions category; Hey guys, I got a problem With my ipad mini. It randomly shuts down in a weird way. The screen freezes for a second then ...
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By twerppoet
  • 1 Post By AdmiralAdama
Thread: Ipad mini problem :(
    284171
    Mar 2013
    5
    Hey guys, I got a problem With my ipad mini. It randomly shuts down in a weird way. The screen freezes for a second then goes black slowly, like the screen color fades away and then completely shuts down. Then, it restarts itself. Then today it shot out codes all starting with [NAND]. Any ideas with what is wrong? I already factory reset it using the ipad itself but would plugging it into a desktop and putting it into recovery mode help at all? It happens intermittently, since I'm typing this question on the ipad itself and before i couldn't even unlock it without it shutting itself down lol. The ipad is not jail broken and is currently running on 6.1.2
    1520 times
    Walla Walla, WA
    15,430
    If you've already done the restore, then I'd contact Apple. Sounds like an intermittent hardware problem, probably RAM. Your iPad Mini should still be covered by Apple's limited hardware warrantee.
    KevinJS likes this.
    284171
    Mar 2013
    5
    Since my grandfather gave it to me as a present and he bought it online from apple will I be able to go to any apple store location and will they cover it?
    85546
    575 times
    Aug 2011
    Edmonton AB Canada
    9,845
    The Apple Store will have records of the purchase. You don't even need a receipt. Call ahead and set up an appointment at the Genius Bar. Before you go, do a backup, because they will likely exchange it on the spot, and you will lose any data. When you have your new one, you can set it up from the backup of the old one.
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
    111434
    524 times
    Oct 2011
    Near the Ionian Nebula, still searching for Earth
    9,399
    Because you're getting a NAND code on the screen it sounds like a flash issue. Like twerppoet and Kevin said, that's hardware which is covered by the 1 year manufacturers warranty.
    One question - has the device been dropped, knocked or shocked, that you're aware of?
    284171
    Mar 2013
    5
    Quote Originally Posted by KevinJS View Post
    I backed It up this morning using iCloud and I have an appointment at 2:20 today,
    284171
    Mar 2013
    5
    Quote Originally Posted by AdmiralAdama View Post
    It was dropped in January about 5 inches from tile, it landed on its top right corner. The only damage was some finish chipped off and there is a very tiny dent, but I don't think that would be the cause of the issue., do you agree?
    111434
    524 times
    Oct 2011
    9,399
    Quote Originally Posted by Billkulis View Post
    Anything is possible. A corner shot, even 5 inches, can produce quite a shock to the chassis. Often the screen will crack or splinter. You're lucky that way. Internally some components are delicate and can crack or, come loose.
    Tell the Genius up front as they'll note the finish damage and dent. If there's internal damage as opposed to a part defect, you may be required to pay a repair charge if it's deemed as a result of dropping the mini.
    Sorry to say but you should know this going in.
    Good luck and we hope it works out to your satisfaction.
    KevinJS likes this.
    284171
    Mar 2013
    5
    *update* I received a new iPad mini with no problem,
    111434
    524 times
    Oct 2011
    9,399
    That is very good news. Thanks for letting us know the outcome.
  1. Problem with connecting ipad mini to iTunes
    By Kay2k in forum New Member Introductions - Site Assistance
    Last Post: 03-14-2013, 07:14 PM
  2. Problem with iPad Mini's accelerometer
    By applesky in forum iPad Mini Forum
    Last Post: 01-23-2013, 12:35 PM
  3. Mini problem with IPF app
    By Alanfujii in forum iPad Mini Forum
    Last Post: 11-03-2012, 11:50 PM
ipad mini keeps shutting down
ipad mini randomly reboots
ipad mini randomly shuts down
ipad mini shuts down
ipad mini shuts down unexpectedly
ipad mini shuts off
ipad mini shuts off randomly
ipad mini shuts off unexpectedly
Tags for this Thread
