a huge concern about my Mini's battery
This is a discussion on a huge concern about my Mini's battery within the iPad Mini Forum forums, part of the Apple iPad Discussions category; Howdy! I'm a newbie here so cut me some slack if I'm overreacting. Here's the thing. I boght my Mini 3 weeks ago and spent ...
Results 1 to 2 of 2
    281476
    Feb 2013
    44
    Howdy!
    I'm a newbie here so cut me some slack if I'm overreacting. Here's the thing. I boght my Mini 3 weeks ago and spent so much money on it that every single possibility of damaging it scares me to death
    I'm concerned about my battery, its lifespan in particular. Could I have possibly done any harm to it if:
    1) Right after buying the Mini I didn't let the battery level go to 0% but instead started charging it when it reached 12%
    2) I took it on a trip to a very cold place and carried it around because I didn't want to leave it in the shabby inn I was staying at. Could low temperatures damage the battery? I didn't use it outside, I just carried it around in my bag and it was OFF most of the time.
    3) I recently discharged it totally (0%) and then fully charged it again.
    4) Recently I've been charging it when my Mini reached 10% or 15%.
    Should I be concerned? How can I prolong my Mini's battery life? How can I check if I haven't damaged the battery?
    Thanks a lot for your advice!
    Take care
    139850
    20 times
    Dec 2011
    Denver, CO
    639
    You should be fine. Better cold temps than having it in extreme heat conditions. Apple states that the preferred operating temperature for iDevices is somewhere between 32 degrees (F) and 96 degrees (F). As for charging and discharging, given battery technology these days it is ok to charge when you need to. Apple recommends you fully discharge the battery (from a full charge) then charge it back up (uninterrupted) once a month to calibrate the battery meter. If you really want to get into the chemistry and fine art of preserving the iPad's battery you can but it is almost more of a hassle than what its worth. If you would like to know more please ask.
    iPhone 4s 64GB White (Jailbroken), The "New iPad" 16GB Black (Stock), Past devices: iPad 2, HTC Hero, HTC Evo, HTC Evo 3D, ASUS Transformer.
  1. Outstanding iPad Mini Battery Life - Over 15 Hours
    By iBushPilot in forum iPad Mini Forum
    Last Post: 12-30-2012, 06:35 AM
  2. Replies: 1
    Last Post: 10-15-2012, 01:37 PM
  3. Replies: 0
    Last Post: 10-12-2012, 11:46 AM
  4. Reason for concern?
    By texaslonghorn in forum iPad Apps
    Last Post: 11-13-2010, 09:54 AM
how to prolong the lifespan of ipad mini battery
