Camera Connection Kit stopped working
This is a discussion on Camera Connection Kit stopped working within the iPad Help forums, part of the Apple iPad Discussions category; I've been taking pics and importing them to my iPad from the camera connection kit for a few weeks now. I went to get some ...
Results 1 to 5 of 5
    14474
    Sep 2010
    Lehigh Valley, PA
    I've been taking pics and importing them to my iPad from the camera connection kit for a few weeks now. I went to get some pictures off of the cam last night, and nothing. Nothing happens at all. Nothing has changed about the camera or the card. And I know that the iPad is seeing the SD adapter because if I power it off and plug in the adapter, it turns on. But its not even giving me an error message. I'm able to pull the pics off on my PC. I tried formatting the card and still not working. My camera (Olympus E-PL1) doesnt seem to work with the USB connector plugged directly into it either. I'm really confused, because nothing has changed other than the fact that it works....
    12489
    Aug 2010
    Columbus, Ohio, USA
    16
    Did you format the SD card in your camera or computer. You should always format in the camera in order to have the proper folders installed.
    2888
    48 times
    Apr 2010
    Fort Wayne, IN
    1,220
    Did You RE-boot your iPad?
    It just sometimes seems that when all else fails, rebooting the iPad cures or fixes the problem. That seems to be the advice most often offered. Rebooting is holding down the sleep button until you get the power off slider, slide to off. Wait a little bit then press and hold down the sleep button until you get the apple logo.
    If that doesn't work, then consider syncing your iPad and restore.
    Welcome to the Forum!
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    Second the reboot suggestion.
    Also check you didn't lock the card by mistake when mounting it.
    14474
    Sep 2010
    Lehigh Valley, PA
    Thanks for the replies. It wasnt any of these things. The card and kit worked fine in a friends iPad. I ended up having to do a complete restore. No idea what caused the problem. I had to set it up as a complete new device... Weird.
  1. 3g on my iPad stopped working
    By MODERN1ST in forum iPad Help
    Last Post: 09-13-2010, 11:58 PM
  2. Replies: 3
  3. Email stopped working
    By Stubert in forum iPad General Discussions
    Last Post: 07-18-2010, 08:30 PM
  4. auto start of itunes stopped working
    By jrw in forum iPad Help
    Last Post: 07-02-2010, 07:30 PM
  5. iPod app stopped working - PLEASE help...
    By cm24 in forum iPad Help
    Last Post: 05-23-2010, 08:22 AM
5 1 camera connection kit isnt working
camera connection kit ipad 2 has stopped working
camera connection kit stop working
camera connection kit stops
camera isnt working on ipdad
connecting olympus e500 to ipad
ipad camera connection kit olympus
ipad camera connector stopped working
ipad sd camera connector don't work suddenly
sharkk camera connection kit isnt working
why isnt my ipad camera connection not working?
