ipad3 suddenly not charging ?!
This is a discussion on ipad3 suddenly not charging ?! within the iPad Help forums, part of the Apple iPad Discussions category; hi everyone i've had my ipad 3 for six months now and it's been great. i plugged it in tonight and it was at 10 ...
Results 1 to 3 of 3
    268093
    Dec 2012
    bc, canada
    Unhappy ipad3 suddenly not charging ?!
    hi everyone
    i've had my ipad 3 for six months now and it's been great. i plugged it in tonight and it was at 10 percent. i checked it about three hours later to use it and it's still at 10 per cent. ! the only difference is that last night i put it in he new smartcase. i had a smart cover before. i had it in my purse today and it may have come into contact with cold drinks or my keys so would that do it? it also could have contacted both of those yesterday too. didnt plug it in last night so not sure if it would've charged then. it's always charged in this wall socket before and nothing is different with it either.
    please help. and thanks.
    48665
    481 times
    Brisbane, Australia
    19,268
    Hi and welcome to the Forum!
    When you plug your iPad in to the power supply do you see the little lightning bolt which signifies that it is charging? If not check to see if your new case is hindering the plug at all. Also have a look at your iPad to see if anything is lodged in your dock, don't go poking anything in it though. Check to make sure your USB is plugged in properly to the charger. Also check your power outlet is working. Do you have an iPhone or other device with which to check your charger? as this may be the culprit here......I had one that stopped working after a couple of months. Check all these and let us know.
    Tutorial on creating posts on the Forum
    Creating Posts and Starting New Threads - How To
    iOS5 Tips and Tricks
    Easy pictorial shortcuts & Helpful places. - For People new to the iPad.
    iPad 2 64gb 3G
    95966
    2 times
    Sep 2011
    NYC
    37
    Follow the instructions given above. Leave the iPad in open warm place (NOT HOT place) for a couple of days with some silica gel packs around/on the home button. Then perform regular charging. If this fails, take it to Apple store for investigation. I read on the web somewhere that Apple gives you new iPad for $105 if your iPad battery dies, so if its your battery, may be its worth.
    I came across this issue a while ago. DS spilled water on iPad and it was acting really erratic. The screen was unresponsive, acting like OCD, buzzing screen ( hard to explain). No charging. I was totally stressed out. I left it on the shelf for 2 days and it was fine. I suspect it was water that was causing troubles.
  1. Replies: 9
    Last Post: 12-24-2012, 07:20 AM
  2. Ipad3 charging battery problem
    By bettyg in forum Siri for the New iPad
    Last Post: 08-23-2012, 06:23 AM
  3. Charging iPad3 with 7w charger - is it possible?
    By snowman1235 in forum iPad 3 Forum
    Last Post: 08-10-2012, 01:57 PM
  4. 12/28v charging for ipad3
    By chris.suter in forum iPad 3 Forum
    Last Post: 07-13-2012, 05:15 PM
  5. Charging iPad3 Question
    By kippyw in forum iPad Help
    Last Post: 05-17-2012, 04:26 PM
ipad 3 not charging
ipad 3 not charging on socket also
ipad 3 not charging with wall charger
ipad 3 say not charging 12w
ipad 3 suddenly not charging
ipad 3 suddenly not working
ipad 3 wall charger not charging
ipad not charging
ipad started saying not charging
ipad suddenly not charging
ipad3 not charging
why ipad 3 is not charging from wall
