Another Photo Sync Problem
This is a discussion on Another Photo Sync Problem within the iPad Help forums, part of the Apple iPad Discussions category; Initial sync worked as expected. Subsequently added some new folders from iPhoto to sync as well and they don't appear on my iPad. They are ...
Results 1 to 2 of 2
    14272
    Sep 2010
    NY
    Initial sync worked as expected. Subsequently added some new folders from iPhoto to sync as well and they don't appear on my iPad. They are in iPhoto, they are jpgs. I'm syncing to a MacBook Pro.
    There are about 1400 pics selected and I have varied the selection with the same results. When iTunes reaches the photos it always says "optimizing x of 355 photos for IPad". It goes through once from x=0 to 355 then begins again with the same message, a new status bar and goes through 0 to 355 again. It then says syncing photos and the sync ends without an error message. However, when it is done all the same photos are on my iPad and none of the new photos have synched.
    I turned photos off, it went through the same process and did empty the photos from the device. I then resynced with the photos I wanted selected and only the old photos reappeared. Tried tossing the iPad photo cache, same result. Any suggestions?
    6507
    Jun 2010
    Seattle
    459
    It might be a filename or folder name that it doesn't like. Check what the 355 or 356th photo is in your folder and see if the name has any special characters.
    It also could be a corrupt file. Try getting rid of the 355 and 356th photo to see if that helps.
    iPAddict - 16Gig WiFi with Zagg InvisibleSHIELD Front - clear Hard Candy Sleek case - Built NY sleeve - Freedom Pro folding Bluetooth keyboard - Microsoft Bluetooth 6000 keyboard - Boxwave stylus - DIY LEGO stand, 3feet stand & DIY fold-flat stand
  1. iPad Photo Question/Problem
    By fairoasis in forum iPad Help
    Last Post: 09-25-2010, 06:09 PM
  2. Ipad Photo sync problem with Windows 7
    By Heroeswanted in forum iPad Help
    Last Post: 08-10-2010, 01:50 AM
  3. Problem with the photo app after upgrade
    By Hansg in forum iPad Help
    Last Post: 07-25-2010, 04:25 PM
  4. photo sync problem
    By Nerdbird in forum iPad Help
    Last Post: 07-08-2010, 06:26 PM
  5. Photo Sync :(
    By !SUPER! in forum iPad Help
    Last Post: 07-06-2010, 12:34 AM
error 1156 ipad
error code 1140 for apple ipad z& ipod
ipad error 1140
ipad error 1156
ipad sync error 1140
ipad sync error 1156
iphone error 1140
iphone error 1156
iphone sync error 1156
itunes error 1140
itunes error 1156
sync error 1140
