Ipad 64 Wifi 3G, Not chargeable with Wall charger or USB Cable is now frozen at Boot
This is a discussion on Ipad 64 Wifi 3G, Not chargeable with Wall charger or USB Cable is now frozen at Boot within the iPad Help forums, part of the Apple iPad Discussions category; Hi This is my 1st post in this forum , and iam sorry its asking for help and advice I have a ipad 64 3g ...
Results 1 to 6 of 6
    14152
    Sep 2010
    India
    Angry Ipad 64 Wifi 3G, Not chargeable with Wall charger or USB Cable is now frozen at Boot
    Hi
    I have a ipad 64 3g that was running fine for 2 weeks, it was jailbroken.I had ample time to play with it and load critical applications.It stated with a sync issue about 5 days back, i spend a night on it installing,deinstalling, cleaning registery entries of Itunes and the whole cycle with different Ipad/Iphone/Ipod cables.It did not sync and the battey was alos running low as i found that it was now not charging too.Therfore i spend another 2 days trying with all Iphone charger and changing USB cable with nothing helping. Finally i tried resetting it to factory default. After that for 3 days all its shown is a RED pulsating low battery with a ~ icon.
    Today morning after yesterday nights pluggin it it into wall plug it showed a apple boot logo, after a few ( about 20 25 times reset+ home screen press ) it once showed th "USB Cable to Itunes SCREEN" i was happy that it will allow me to resore, but nothing happened when i plugged it to my Laptop Screen ( Dell 15mx Alienware ).
    Since then i get only the "RED pulsating low battery with a ~ icon" as long as its connected to wall adapter , if i remove it from the charging wall adapter i get a "RED pulsating low battery with a ~ and adapter icon".
    The ipad is struck with these both screens as mentioned above.
    I have searched the net all across including many forums incl apple with nothing helping by.Iam kinda struck
    Now i brough this Ipad from US and iam in India now, where the Ipad is not yet launched, therfore iam without support. I called up the apple helpline amd they redirected me to an "expert" who again asked me to get in touch with the local " service center "
    I called up the local service center just to confirm that they can fix it,but they replied that they do not serive Ipad. So iam royally struck with ipad puzzle box.
    Any help to solve this puzzle is appreciated.I have exhausted myself and at my wits end.
    Thanks for your time to go across the lenghty post and intent to help
    Iyer
    6507
    Jun 2010
    Seattle
    459
    Power it completely off. Then have iTunes open on your computer. Once the computer is ready, press and hold the Home button AS you plug in the dock connecter to the iPad. Keep the Home button pressed and iTunes should recognize the iPad and ask about restoring. You can now let go of the Home button and proceed with the restore prompts in iTunes.
    iPAddict - 16Gig WiFi with Zagg InvisibleSHIELD Front - clear Hard Candy Sleek case - Built NY sleeve - Freedom Pro folding Bluetooth keyboard - Microsoft Bluetooth 6000 keyboard - Boxwave stylus - DIY LEGO stand, 3feet stand & DIY fold-flat stand
    14152
    Sep 2010
    India
    The problem is its just showing the "Red Low Battery Screen" I dont even get the logo or Itunes screen, hence when i connect it to my Laptop with USB, it does not get recognised.That's how it is since last 3 days , i have kept in on continious charging with no difference in outcome.
    Any advice would be helpful Purpleorchid.
    14338
    Sep 2010
    Ukraine
    Hi.
    It's a hardware problem, I got the same issue with my iPad. It's needed to change hardware component, try to found service center which can help you.
    6931
    Jun 2010
    Beavercreek, Ohio (Dayton PO
    174
    Are you in India just temporarily or is this a permanent change of residence. If you are returning to US, wait till you get back and get to a service center. Or call the Apple service center.
    If you are permanently in India, try to get it mailed back to where you purchased or to the Apple Service Center that your local Apple store tells you where to send. Good luck.
    Mel Lammers
    11919
    10 times
    Aug 2010
    Virginia, USA
    732
    Get a new USB cord
    Sounds like yours is bad. I've had a couple go bad and would no longer charge the iPad. The only solution is to replace it. You cannot synch a dead iPad and the USB cord to the computer will not charge it.
  1. Iphone sync cable not same as ipad cable
    By swelson in forum iPad General Discussions
    Last Post: 10-12-2011, 01:39 AM
  2. Question about the ipad wall charger.
    By willowzxx in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-27-2011, 09:25 PM
  3. iPhone wall charger does work with ipad
    By mrdinh in forum iPad FAQ
    Last Post: 12-22-2010, 01:39 PM
  4. iTunes Won't Boot Up in iPad
    By yvrgal in forum iPad General Discussions
    Last Post: 11-07-2010, 03:59 PM
  5. iPad Boot Times
    By iDan in forum iPad General Discussions
    Last Post: 01-30-2010, 07:05 PM
charging ipad in india
how to charge ipad in india
ipad charger for india
ipad charger india
ipad charging in india
ipad india charger
ipad not charging in india
ipad will not charge with wall charger
Tags for this Thread
