I Pad Won't Power Up and Won't connect to I Tunes
This is a discussion on I Pad Won't Power Up and Won't connect to I Tunes within the iPad Help forums, part of the Apple iPad Discussions category; This happened a few days ago and I was able to connect to I Tunes and repower. But now I am staring at a black ...
Results 1 to 3 of 3
    12994
    Aug 2010
    Montana
    This happened a few days ago and I was able to connect to I Tunes and repower. But now I am staring at a black hole.
    12994
    Aug 2010
    Montana
    I just tried a cold boot by holding down the Home button and the on off switch for more than 10 seconds a finally the apple came on and because it was connected to the computer, it is now displaying a I Tunes logo and the end of the USB cable. I Tunes suggested if I was having trouble to restore factory settings. So I'm doing that. Any down side?
    13799
    Sep 2010
    rock hill sc
    Initially, this sounds like a depleted battery. Be sure that you have a fully charged battery.
    Being connected to the itunes, you shoud be able to have been auitomatically backed up.
    By restoring, you will lose the data you entered: photos, music, contacts, notes, apps... but they will all be backed by by the itunes and whatever contact list you are using.
    My suspiciaon tho is that the "black hole" is that the battery is/was critically low... put it on its charger for 6-8 hours, see what happens beofre you do anything.
    just my 0.02
    davis
  1. need to respring after power on
    By ert6ic in forum iPad Help
    Last Post: 07-20-2012, 04:52 AM
  2. iPad - Tunes in your car
    By AbsoluteMayheM in forum iPad General Discussions
    Last Post: 07-09-2010, 02:22 PM
  3. Pocket tunes for Iphone Works full screen!
    By rhinohd in forum iPad Apps
    Last Post: 06-30-2010, 05:31 PM
  4. First synchronise to I-Tunes.
    By Northernstar002 in forum iPad Help
    Last Post: 06-30-2010, 12:51 PM
i pad 2 start up
i pad won't power up
i pad won't start
ipad won't power up
ipad wont power up
ipad wont turn on or connect to computer
my ipad won't powerup
my ipad wont turn on or connect to my computer
