Help
This is a discussion on Help within the iPad Help forums, part of the Apple iPad Discussions category; I have two Apps which won't download. They just say waiting...I can't delete them in the usual way. Any ideas?...
Results 1 to 7 of 7
Thread: Help
    258184
    Nov 2012
    Help
    189017
    Apr 2012
    Lake Worth TX
    8
    It could be the update. If you haven't updated, you may need to. iMovie will not update without the new iOS, for example. If you have updated and it still has the issue try a hard reset and then try to go back into the app store to update.
    258184
    Nov 2012
    Quote Originally Posted by ewoodson
    Thank you for your feedback. Can I ask what a hard reset is?
    189017
    Apr 2012
    Lake Worth TX
    8
    Hold the power button and the home screen button down at the same time until the screen goes black.
    258184
    Nov 2012
    Any risks?
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Quote Originally Posted by LynEdwards2004
    Any risks?
    I've done it many times on two different iPads and two different iPhones with no ill effects whatsoever.
    258184
    Nov 2012
    Great many thanks
