iTunes could not connect to the iPad because it is locked with a passcode
This is a discussion on iTunes could not connect to the iPad because it is locked with a passcode within the iPad Help forums, part of the Apple iPad Discussions category; Basically, I have my iPad and recently one of my friends had "accidentally" changed my passcord and can't "remember" it >____>. I know that from ...
Results 1 to 8 of 8
    254358
    Oct 2012
    I know that from here I should just use a backup and restore my device but when I did it came up with the message:
    "iTunes could not connect to the iPad because it is locked with a passcode. You must enter your passcode on the iPad before it can be used with iTunes."
    I did some research, and apparently this is because my iPad has a passcode, I need to enter it before I can back it up. However, I don't know that passcode and I have no means of finding out what it is. Also if it matters, the computer I normally synced it to is not with me right now and I won't be getting it back until a week.
    Does anyone have any ideas on how to do a hard reset/restore without using my original computer/laptop I synced it with while it's locked by a passcode that I don't know of?
    85546
    577 times
    Aug 2011
    Edmonton AB Canada
    9,850
    You will need to wait until you have access to the computer which has your backups.
    Once you do, you can restore it and use a backup which predates the password. Otherwise, you have no choice but to restore from scratch using a different computer.
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
    254358
    Oct 2012
    Quote Originally Posted by KevinJS View Post
    I don't think I can afford to wait. I would rather do a restore from scratch... Do you have any idea on how to do that?
    85546
    577 times
    Aug 2011
    Edmonton AB Canada
    9,850
    I don't know of any way to do it without access to a computer.
    Assuming you have a computer available, plug it in and use iTunes to restore to factory settings. When you have access to your own computer you can restore again from your backup.
    254358
    Oct 2012
    Well I did try it on my separate computer, but the message "iTunes could not connect to the iPad because it is locked with a passcode. You must enter your passcode on the iPad before it can be used with iTunes." pops up and I don't know what the passcode is. Apparently it won't let me restore without it. Unless there's away to just disregard it and restore it, I wouldn't mind losing my info; it didn't have any pictures or videos that I didn't already transfer to my computer.
    85546
    577 times
    Aug 2011
    Edmonton AB Canada
    9,850
    Did you authorise the other computer? That might do it. It's under the Store menu on iTunes.
    254358
    Oct 2012
    That seemed to do the trick. Thank you!
    85546
    577 times
    Aug 2011
    Edmonton AB Canada
    9,850
    No problem. Glad it worked. Next thing is to keep your buddy away from it.
  1. Passcode locked out of ipad and itunes not recognising. HELP!!
    By Roisinpsbroad8701 in forum iPad 2 Forum
    Last Post: 08-05-2012, 08:28 PM
  2. Passcode help, locked out
    By cyberdog in forum iPad Help
    Last Post: 04-23-2012, 01:47 AM
  3. How to connect ipad to itune with passcode locked
    By yeolarry in forum iPad Help
    Last Post: 01-19-2012, 07:17 AM
  4. Replies: 15
    Last Post: 06-20-2011, 02:24 PM
  5. IPAD 3G 64GB - Locked @ "Connect to Itunes" screen
    By yaponchik in forum iPad Help
    Last Post: 09-15-2010, 09:47 AM
itunes cannot connect to ipad because it is locked with a passcode
itunes could not back up the ipad because it is locked with a passcode
itunes could not connect to ipad because it is locked with a passcode
itunes could not connect to the ipad
itunes could not connect to the ipad because it is locked with a passcode
itunes could not connect to the ipad because it is locked with a passcode. you must enter your passcode on the ipad befo
itunes could not connect to the ipad passcode
itunes could not connect to the iphone because it is locked with a passcde. you must enter your passcode on the iphone b
