Results 1 to 2 of 2
    118496
    2 times
    Oct 2011
    India
    90
    A help needed with how to play subtitles.
    I use an ap called aceplayer which supports all sorts of video formats.the app says it also supports most of the subtitle formats too. But I can't load subtitles along with the movie.you can't transfer the video and subtitle file as a single folder into the app.only separate transfer is possible.
    Anyone else uses the app?or how do u play subtitles in other video apps?please help
    from my white I pad 3G/wifi 16 gb
    Supporting Vendor
    154
    21 times
    Jan 2010
    311
    They do have a faq on their website, but that doesn't help much:
    20.The subtitle is not show, why?
    Maybe you should click the “i” button and select the subtitle encoding .
    When you play videos from some server, maybe the subtitle is not shared, you should check whether the subtitle is in the files list.
    21. How to play MP4, M4V or MOV with the “.srt” subtitle file?
    Close the QuickTime in the settings.
    I've seen people mention goodplayer and avplayerhd quite a few times. Those might be a better choice, but considering that AcePlayer sells for $5, you might want to try and contact their support department.
  1. Replies: 1
    Last Post: 04-19-2012, 12:12 AM
  2. Help needed to play UDP Stream on iPad 3
    By delta1 in forum AirPlay
    Last Post: 04-10-2012, 03:26 AM
  3. Help needed to play UDP Stream on iPad 3
    By delta1 in forum iPad General Discussions
    Last Post: 04-10-2012, 02:46 AM
  4. Subtitles
    By Clothears in forum iPad Help
    Last Post: 10-28-2011, 06:44 AM
  5. Subtitles
    By arttext in forum iPad Help
    Last Post: 09-26-2011, 04:24 AM
aceplayer app subtitles
aceplayer subtitles
aceplayer subtitles not working
avplayerhd subtitle not showing
cannot play subtitle using aceplayer
how to play a separate subtitle file in aceplayer
how to play subtitles in aceplayer
how to play subtitles on ipad
play mp4 on ipad with subs
srt aceplayer
subtitles not working in avplayerhd
subtitles on aceplayer
