Problem with iBooks
This is a discussion on Problem with iBooks within the iPad Help forums, part of the Apple iPad Discussions category; My iBooks shows up for a moment without getting books and documents and then disappears after a few seconds. I have a iPad 2, model ...
Problem with iBooks
My iBooks shows up for a moment without getting books and documents and then disappears after a few seconds. I have a iPad 2, model MC774KN. How to reinstall the app and all my boks and dokumenta?
I tried Claes THE app, and restarted the iPad more times.
10-27-2012 05:37 PM
Hi and welcome to the Forum!
When an app behaves strangely it is best to close it completely and then relaunch it. From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar. These are all the apps that you have opened at one time. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it, now press the home button to return to your screen. It's also a good idea to close all these apps, as it helps the iPad run smoothly.....see if it is now working, if not I would try a reset.
Hold the power off button and the home button simultaneously, keep holding them in and you will see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start.
Let us know how you go.
I have tried both more times. Now I have tried to uninstall and then reinstall the iBooks app. But the same happend again. I am not able to do work with the app.
Originally Posted by
magnelar
Just wondering if this is an OS incompatibility working here. What OS is your iPad on, have a look in Settings - General - About and look for version.
magnelar
Version : 6.0 (10A403)
Well that's what you should have......not sure what is causing it but would think its a setting doing this.
Do you have any restrictions set up at all? Settings - General - Restrictions. Is iBookstore turned on here?
I've moved your thread to our Help Section where you will receive a better response.
iBook store restrictions Allowed : iBookStore : I (on) (I can not changes this settings?)
I can change, but have to tip my security code.
i had a similar problem before. It was 5.1.1 though. My solution was to reinstall iBooks from the app store. I remove the previous iBooks, then went to the app store to download the iBooks. I installed it directly from the ipad.
Hope this helps
I have un-installed and installed again more times and now I have run a upgrade to 3.0.1, but still the same happened as described in the release notes : unexpected stop should bee fixed. But unfortunately not in my case??
- You may not post replies
- You may not edit your posts
Forum Rules
By dmv501 in forum New Member Introductions - Site Assistance
Last Post: 06-16-2012, 02:20 AM
By anneUK in forum iPad 2 Forum
Last Post: 04-28-2012, 12:54 PM
By 4528 in forum iPad General Discussions
Last Post: 03-05-2012, 01:17 PM
By Fez in forum iPad Help
Last Post: 08-24-2011, 05:21 AM
By nmpettus in forum iPad Help
Last Post: 05-02-2011, 09:57 AM
ibook problems
ibooks 3.0.1 fix 5.1.1
ibooks problem
ibooks store not working
ibookstore not working
ipad 3 ibooks problem
problem with ibooks
problem with ibooks on ipad
problems with ibooks
problems with ibooks in australia
problems with ibooks ipad
problems with ibooks on ipad
