Hi.
I bought my Ipad 2 wifi about a year ago from a 3rd party (Family member bought a month prior and recently purchased a new Macbook so decided to sell). Everything was as usual, all the accessories were in the box and the Ipad screen still had the plastic coating. I mainly use the Ipad for school work as I am a student, however I do often play some games as well. I have used roughly 7/16GBs of the memory. Everything has being working just fine for the past 11 months or so, occasionally apps will freeze and need to be restarted, but as everyone knows, this is common for computers all shapes and sizes.
Today it began to freeze for a brief moment and then turn black for a few moments. Then it would flash back to the application I was using (at this time I was switching between games and safari). It would flash back and forth numerous times for about a minute before I did a simple reset (Hold the sleep button until the red bar appeared). After it reset, the problem still occurred after 20 seconds. I then proceeded to do a hard reset (Hold sleep and home button until reset). Afterwards, the flickering had stopped and normal activity proceeded.
A couple of hours later, the same problem occurred, so I again followed the previous procedure, and once again the system was back to normal. I now wonder, is this a hardware problem? Is there anyway to know without going into Apple? If so, am i screwed? As I mentioned earlier, I bought this from a 3rd party (Unfortunately no receipt included, however no I have not jailbroken) so I was not able to get warranty let alone extended warranty. Is it too late to get applecare? Any and every advice relating to this topic would be greatly appreciated.
Thank you, Ben
LinkBack URL
About LinkBacks
