Pleaese your help
This is a discussion on Pleaese your help within the iPad Help forums, part of the Apple iPad Discussions category; Dear All... i tried to upgrade my un jail broken ipad3 Gsm from the original firmware 5.1 to ios 6.0 Via iTunes. i made a ...
Results 1 to 6 of 6
    224170
    Jul 2012
    8
    Pleaese your help
    Dear All...
    i made a backup with iTunes and icloude .
    during restore , and while ipad is restoring , the iTunes upgrade bar seemed faster the the ipad upgrade bar , and the error -1 appear , and ipad stuck in iTunes recovery mood.
    please your advice
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,265
    Pleaese your help
    Have a look and a go with this tutorial: TUTORIAL - Failsafe method to restore the current version of IOS
    If the steps are followed exactly as written, you should end up with a stock iPad3 running iOS 6.
    Good luck and let us know how you get on.
    P.S. And, since you talk about a jail broken iPad, I've taken the liberty of moving your post over to the Hacking section. Thanks for your understanding.
    224170
    Jul 2012
    8
    no , mt device has no jailbreak on it
    224170
    Jul 2012
    8
    i tried the upgrade many times , and i followed the instruction in the tutorial , but always the error -1 shut the restore process
    13576
    743 times
    Aug 2010
    9,265
    Pleaese your help
    Oops, my apologies. I missed that little "un" word. So, I moved it back to the help section.
    I'm sorry the tutorial didn't work (it should work for non-jail broke iPads too). However, if iTunes persists on giving you an Error-1, you may have a hardware problem. Try doing the restore on a different computer or after disabling any security software. If that doesn't work my recommendation is to take it to the Geniuses at the Apple store for assistance.
    Again, sorry for the mix-up. Good luck.
    13576
    743 times
    Aug 2010
    9,265
    Pleaese your help
    Please have a bit of patience in getting a response from the forum. Do not post in other threads about your issue.
    I have twice deleted a follow-up question you posted in this thread (An unknown error occurred (-1) while trying to restore Ipad 3 new). Please don't ask there again; keep the conversation about your issue to this thread here [only].
    Thank you.
  1. Replies: 10
    Last Post: 10-19-2011, 11:43 PM
recovery mood for ipad3
