Erase all media and settings RESET HELP!
This is a discussion on Erase all media and settings RESET HELP! within the iPad Help forums, part of the Apple iPad Discussions category; Hi, i have an ipad 3 aka new ipad with 64gb wifi only. It was running on ios 5.1.1 jailbroken. I wanted to reset it ...
Results 1 to 9 of 9
    253190
    Oct 2012
    5
    It was running on ios 5.1.1 jailbroken. I wanted to reset it back to its original state,so I used the ipad reset and also erase all media and settings.
    It has currently been on a spinning icon in the centre for about 1h now. How long does it usually take??
    Im really worried that I messed up somehow.
    253190
    Oct 2012
    5
    Erase all media and settings RESET HELP!-imag0161.jpg Update: 3hours and still spinning. Help Please!!!
    13576
    746 times
    Aug 2010
    Western NY state (USA)
    9,290
    Well, unfortunately, you should not have done the reset all from within the Settings app on a jail broken iPad. That's why it's messed up.
    Your best (only) bet is to restore the iPad and put iOS 6 on it. To restore it, put it into DFU mode (tutorial here: DFU Mode for Dummies) and then open iTunes if it doesn't automatically open. Then, with the ipad connected, you can click the "Restore" button on the main Summary page in iTunes.
    That should fix it. Good luck and let us know how you get on.
    253190
    Oct 2012
    5
    I've held the home and home button and it shutdown. Tried to turn it on and still manages to load.
    The reason I need to reset is to fix my assistive touch button that keeps crashing.
    I know that installing IOS6 will fix it but I still want to retain the youtube app and maps, not the apple maps in the new version.
    Anyway for me to reinstall 5.1.1 or
    fix assistive touch or
    reset to default 5.1.1?
    13576
    746 times
    Aug 2010
    9,290
    Do you have SHSH blobs for iOS 5.1.1? If yes, you might be able to re-restore that iPad3 to iOS 5.1.1. Follow this tutorial here and see if it works for you: TUTORIAL - Re-restore IOS 5.x on iPad2 and iPad3 using redsn0w and SHSH Blobs
    Good luck and let us know how that works out.
    P.S. Sorry about giving advice to upgrade to iOS 6. I thought you meant that when you said you wanted to "reset it back to its original state."
    253190
    Oct 2012
    5
    I only have OTA shsh blobs so I cant restore it.
    Thanks for your help anyway
    166981
    Feb 2012
    UAE
    10
    If you have shsh you can use the latest redsnow to restore 5.1.1 just stitch
    253190
    Oct 2012
    5
    Quote Originally Posted by TimmyBoy View Post
    Redsnow tells me stiching is not available for this version.
    Moderator
    131244
    625 times
    Dec 2011
    Regina,Canada
    14,534
    OTA blobs will not work for the restoration to iOS 5.1.1.
  1. Erase All Content and Settings - JB iOS 4.3.3 Warning
    By f4780y in forum Jailbreaking & Hacking Tutorials & How-To Guides
    Last Post: 03-01-2012, 05:22 PM
  2. Erase all contents and settings
    By Eli02 in forum iPad 2 Forum
    Last Post: 12-23-2011, 01:11 AM
  3. Master code reset, erase all data without computer??
    By JenniferGrace in forum iPad Hacking
    Last Post: 11-18-2011, 08:13 AM
  4. Problem to erase and reset my ipad 2
    By ZibaWal in forum iPad Hacking
    Last Post: 09-26-2011, 09:47 PM
  5. Erase all content and settings?
    By skipper in forum iPad Help
    Last Post: 06-09-2010, 12:38 PM
how long does it take an ipad to reset
how long does it take for a 64gb ipad to erase all data and reset
how long does it take for ipad to reset
how long does it take to reset an ipad
how long does it take to reset ipad
how long does it take to reset ipad 2
how long it takes for the ipad 4 to erease all data
how to reset jailbroken ipad 1 to factory settings
ipad 3 how long erase data and media?
ipad help erase all setting
ipad reset all settings
reset all settings ipad
