Ok so I noticed a strange volume problem on my ipad the other day.
Whenever I record something, even when theres supposed to be sound, the sound is all frizzed up!
It sounds like a frizzed up Tv!
EVEN WHEN ITS TOOK ON DIFFERENT APPS!
This is a discussion on Weird volume problem please help within the iPad Help forums, part of the Apple iPad Discussions category; Ok so I noticed a strange volume problem on my ipad the other day. Whenever I record something, even when theres supposed to be sound, ...
Do a search of the forum for "vacuum cleaner".
That should help. And then read the rule on thread bumping, Amy!
Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
??Originally Posted by KevinJS
Nothing came up for "vacuum cleaner... "
Sorry, Amy. You're right. The search doesn't find it.
OK. Get a vacuum cleaner and use the crevice tool to suck any débris out of the hole above the camera. Try and get a good seal and give it about two minutes.
Okay thanksOriginally Posted by KevinJS
