Mains charging
This is a discussion on Mains charging within the iPad Help forums, part of the Apple iPad Discussions category; My iPad 2 use to charge from mains while switched on now for some reason it will only charge if I switch it off .also ...
Results 1 to 10 of 10
Thread: Mains charging
    242987
    Sep 2012
    5
    Mains charging
    My iPad 2 use to charge from mains while switched on now for some reason it will only charge if I switch it off .also just found out that it will not connect to iTunes its theipad because my IPhone connects with same leads
    48665
    481 times
    Brisbane, Australia
    19,236
    Hi and welcome to the Forum!
    Try a reset of your iPad, this reset will not change anything on your iPad and is akin to rebooting a pc.
    Hold the power off button and the home button simultaneously, keep holding them in and you will see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start. Let us know if this makes a difference here.
    Do you allow your battery to run down totally occasionally? It's a good idea to do this as this will recalibrate it.
    iOS5 Tips and Tricks
    Easy pictorial shortcuts & Helpful places. - For People new to the iPad.
    iPad 2 64gb 3G
    242987
    Sep 2012
    5
    Hi thanks for that tried but still the same
    48665
    481 times
    Brisbane, Australia
    19,236
    I have seen reports of problems with the port, have a look to see if anything has lodged there.
    I've moved your thread to our Help Section where you will receive a better response
    iPad 2 64gb 3G
    242987
    Sep 2012
    5
    Thank you for trying to help nothing in port ii will charge when switch off iPad
    48665
    481 times
    Brisbane, Australia
    19,236
    Hopefully others here will know something more of this problem.....
    and moving it here will reach a larger audience....good luck!
    iPad 2 64gb 3G
    240173
    Aug 2012
    West Yorkshire
    14
    have you tried to do a software up date on the machine - more often than not this is something that apple & many other manufactures recommend is to regularly update the software for the product other than that i'm not too sure myself
    242987
    Sep 2012
    5
    Yes have pressed update in settings says all up to date thanks ant way the strange thing is if I plug the charger into the iPad then shut iPad down it will charge but I can't even get into iTunes to switch it to wi fi contact
    146932
    Jan 2012
    Chicago
    What happens if you start charging with the IPad off then turn it on? Will it keep charging?
    242987
    Sep 2012
    5
    No just tried not charging
  1. Replies: 9
    Last Post: 10-10-2011, 05:54 PM
  2. Dual Ipad 1 / Ipod Classic mains charger ?
    By borischelski in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-12-2011, 10:16 AM
  3. Ipad2 using Mains USB hub
    By Archer in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-02-2011, 08:54 AM
  4. Usb charging
    By owenmorris in forum iPad 2 Forum
    Last Post: 04-01-2011, 12:12 AM
  5. Replies: 7
