My ipad is showing "No WIFI" in the settings wifi menu... and nothing I do seems to make it want to work, including resetting my router. ***? Am I doomed?
This is a discussion on Settings: wifi = "NO WIFI" within the iPad Help forums, part of the Apple iPad Discussions category; My ipad is showing "No WIFI" in the settings wifi menu... and nothing I do seems to make it want to work, including resetting my ...
I had a similar problem with my 1st Gen Itouch.
WIFI was working ok then the next day I got the No WIFI on the Itouch.
In the end I took it back to Apple to fix & they ended up replacing it.
Does your home WIFI work with a PC or other device?
I assume you have tried the Ipad WIFI out at a different spot by this I mean at a cafe or something like that with free WIFI,
Took it to the Apple store. They replaced it yesterday morning. Looks like hardware failure. Yay, fixed!
