when I connect the camara kit to my Ipad always get a warning saying "this device is not supported"
any help will be appreciated.
thank you
This is a discussion on Camara kit problem within the iPad Help forums, part of the Apple iPad Discussions category; when I connect the camara kit to my Ipad always get a warning saying "this device is not supported" any help will be appreciated. thank ...
thank you
I have this same problem.![]()
nothing to it but to do it
You might have to a a dcim folder to the sd card. Mine also did that, I also found a 1g card worked better.
you might check this thread :
Apple - Support - Discussions - Search Discussions
To use it properly - as in transfer images from memory card or camera - you need a DCIM folder. Most if not all cameras store images in this folder by default.
If using the card say for other reasons: transferring files on a jailbroken iPad, then it will always say that...but never causes a problem. All it's looking for is that DCIM folder.
Did you guys try to connect to the USB accessory with the camera's wires?
Not white, not black just passionate shades of grey...
Yuno Wataï Minh
Received today iPad camera connection kit which I ordered from ipadhut.co.uk
iPad Camera Connection Kit | iPad Hut - iPad Cases | iPad Stands | iPad Camera Kit
It works fairly good, so I can upload photos from my camera through USB cable or directly from memory card using a slot in the kit.
On top of that now I can use also standard USB stick, if want to upload photos with that one, just create DCIM folder and put photos into that.
It also allowed to download video file (.mp4) but i couldn't play that one. Need to investigate a bit more.
Trust your instincts, be yourself.
iPad Wi-Fi+3G 64GB
Little slow to transfer a 1.4 meg photo via blue tooth but it works!
I have the same problem with the videos, i can not play the videos that are transferred with the photos. Dies anyone have a solution.
