Jammed volume button
This is a discussion on Jammed volume button within the iPad Help forums, part of the Apple iPad Discussions category; Hi guys
The other day, I was using my iPad and the volume button was totally fine, but when I came back, it was jammed ...
Banned
Hi guys
The other day, I was using my iPad and the volume button was totally fine, but when I came back, it was jammed at the top, and now whenever I try to get the button unjammed the volume turns up all the way and won't let me turn it down unless I use the YouTube volume bar. I have no idea how to get it unjammed! I tried washing it off (because I ate and didnt wash my hands) thinking that would solve the problem, but it didn't, so anyways, if anyone has any idea PLEASE help, thanks.
08-18-2012 12:13 PM
Originally Posted by
Amy Rose The Hedgehog
Hi guys
Well, you can lower the volume in any screen by double "clicking" the home button
If your iPad was locked, just slide the slider down.
If you iPad was being used, on the slide-able app icons that pop up, slide from left to right twice, and a volume slider will also appear.
Who Needs A Dumb Signature?
NOT ME!
My Origin Username: nicknick923 (add me!!!!)
Banned
nicknick923
Ok thanks
Ok thanks
Is that in a way what you were looking for?
NOT ME!
Banned
nicknick923
Well sort of but I meant the top of the volume button on my iPad is jammer and whenever I touch it the volume turns up and I keep clicking the bottom of it to get it to turn down, but the volume just goes straight up all the way again, I'm trying to figure out how I can get it unjammed so I can control the volume.
But anyways I appreciate your help.
Moderator
nicknick923
Did this suggested method actually control your volume? If so,it's a reasonable work around without the expense of a repair cost.
Banned
scifan57
<img src="http://www.ipadforums.net/attachment.php?attachmentid=23121"/>
I wonder how come ive never noticed that before? Thanks for your advice, I appreciate it.
Hi guys
Dude it wont even let me use the youtube bar its permanantly stuck on mute
nicknick923
volume slider is not working its only dented below the volume button thats why its stuck on mute i need somemore helpful advice the dent isnt even that bad but it wont let me turn up the volume ANYWHERE on ANYTHING
- You may not post replies
- You may not edit your posts
Forum Rules
By Sjoholt in forum iPad Help
Last Post: 04-03-2013, 06:51 AM
By The Kleaner in forum iPad Help
Last Post: 11-05-2011, 11:08 AM
By RudyL90 in forum iPad Hacking
Last Post: 08-19-2011, 01:31 PM
By lmdarkins in forum iPad 2 Forum
Last Post: 05-20-2011, 08:25 AM
By Mattmilw in forum iPad Help
Last Post: 04-16-2011, 10:25 PM
disable ipad volume buttons
disable volume button ipad
ipad 2 volume button stuck
ipad sound button jammed
ipad sound button stuck
ipad volume button stuck
ipad volume switch stuck
ipad volume won't turn down
my ipad volume button is stuck
my volume button on ipad is stuck
volume button on ipad 2 stuck
volume button stuck on ipad
