Is there a way to restore an iPad to factory settings
This is a discussion on Is there a way to restore an iPad to factory settings within the iPad Help forums, part of the Apple iPad Discussions category; My brother-in-law had his briefcase stolen while he was moving overseas. It was found and turned into the airlines but he had since replaced everything. ...
Results 1 to 4 of 4
    237069
    Aug 2012
    Canada
    My brother-in-law had his briefcase stolen while he was moving overseas. It was found and turned into the airlines but he had since replaced everything. He sent me his old one but cannot remember the passcode. Is there a way I can reset the iPad to factory settings through my own computer?
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,249
    Absolutely. Just connect the iPad to the latest version of iTunes and select Restore. iTunes will do all the work and when it's done, elect to restore as new.
    Then, you'll have an iPad running the newest iOS (5.1.1) and it'll be good to go (the pass code will be removed with the restore).
    237069
    Aug 2012
    Canada
    When I plug into iTunes it will not connect without a passcode.
    My iTunes was not the program that was used for the initiial set-up of the iPad.
    13576
    743 times
    Aug 2010
    9,249
    It doesn't matter - as I assume you are going to want to set up the iPad as yours. You start out with a "fresh" iPad just like it came out of the box. Then, you start loading your own apps on it, using your Apple ID.
  1. Replies: 7
    Last Post: 04-09-2012, 01:57 AM
  2. Problem after restoring iPad to factory settings
    By ClarkIpad in forum New Member Introductions - Site Assistance
    Last Post: 01-18-2012, 05:00 AM
  3. Restore Factory settings to reset IOS
    By joepauljig in forum iPad Hacking
    Last Post: 01-12-2012, 04:09 PM
  4. Restore factory settings
    By elevate1998 in forum iPad 1 Forum
    Last Post: 11-14-2011, 07:43 PM
  5. Replies: 2
    Last Post: 09-18-2011, 01:10 AM
how to factory reset ipad without itunes
how to reset ipad 2 without itunes
how to reset ipad to factory settings without itunes
how to reset ipad to factory settings without passcode
how to reset ipad without itunes
how to restore ipad to factory settings without itunes
how to restore ipad without itunes
reset ipad to factory default without password
reset ipad to factory without itunes
restoring ipad to factory settings without itunes
