Battery
This is a discussion on Battery within the iPad Help forums, part of the Apple iPad Discussions category; My battery used to last all day. Suddenly, I find that I have to charge my IPad II several times a day. What could be ...
Results 1 to 5 of 5
Thread: Battery
    237010
    Aug 2012
    Battery
    My battery used to last all day. Suddenly, I find that I have to charge my IPad II several times a day. What could be causing that?
    220254
    Jun 2012
    India
    10
    Similar problem. I used to charge only once a week when it was new and extensively used. Now I have to charge every 2 days even though usage has reduced. Also of late the ipad is becoming too hot to hold and use. I'll ask for a replacement if the problem worsens.
    Moderator
    131244
    1426 times
    Dec 2011
    Regina,Canada
    18,544
    Quote Originally Posted by wildsdi
    How long have you had your iPad? The reason I ask is that if the battery capacity drops by 50% or more in the first year,it is covered under warranty and you will get a free exchange for a new or refurbished iPad.
    220254
    Jun 2012
    India
    10
    It's barely 1 month old. How do I test if battery capacity has dropped by 50%?
    Moderator
    131244
    1426 times
    Dec 2011
    Regina,Canada
    18,544
    If you use the iPad in the same way you did when it was new and the battery only lasts half as long then you should take it in to an Apple store for a genius bar appointment.
    This thread has some excellent advice on how to test your iPad battery.
    https://discussions.apple.com/thread...art=0&tstart=0
  1. How often do u charge battery to save battery life
    By eddiethebhoy in forum iPad General Discussions
    Last Post: 04-24-2012, 04:29 PM
  2. Battery
    By hcha in forum iPad 2 Forum
    Last Post: 03-10-2012, 04:48 PM
  3. Battery
    By Hugh53 in forum iPad 2 Forum
    Last Post: 10-10-2011, 01:42 PM
  4. looking after the battery
    By Gertrudefrombasildon in forum iPad 2 Forum
    Last Post: 09-29-2011, 03:55 AM
battery
checking capacity apple battery drops below 50%
how do ,
how do i know if my ipad battery drops below 50%
how to check your iphone battery drops below 50%
how to know if your iphone has dropped below 50% batteryu
how to tell if iphone battery at 50%
ipad battery only last for 1 day
