Battery Replacement ?
This is a discussion on Battery Replacement ? within the iPad Help forums, part of the Apple iPad Discussions category; I don't have one yet but if you have to send it back to have the battery replaced at some point...can you "save" all the ...
Results 1 to 7 of 7
    11187
    Aug 2010
    NJ
    106
    I don't have one yet but if you have to send it back to have the battery replaced at some point...can you "save" all the apps you bought and put them back in the I-Pad you get back?
    They say once you have the battery replaced all your stuff is gone when you get it back?
    Thanks, Ken
    iPad Enthusiast!
    10084
    Jul 2010
    Oceanside CA
    44
    Yeah just backup your ipad on itunes before taking the ipad in, then when you get a new ipad just restore it on itunes from that backup.
    Also anything that you purchase from the itunes store can be re-downloaded at any point without having to pay for it again. So in the case you dont restore from a backup, you can always go back into the itunes store and re-download all the apps youve paid for.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    It is important to mention that when you send your iPad in for a battery replacement, you do NOT get your iPad back! You get back a refurbished iPad with a new battery and that means it will have NONE of your stuff on it so it is imperative to sync your iPad BEFORE you send it in.
    The good news is that the battery is supposed to be good for at least 1000 charge cycles so even if you completely discharged and charged your iPad every day, it would take nearly three years to reach this point. Apple actually says the "average" life span should be around 5 years.
    4993
    3 times
    May 2010
    St.Louis Mo
    420
    I would think they would have a power unit plugged into th iPad when they Changed the battery or at least do the back-up for you.
    Al.
    4993
    3 times
    May 2010
    St.Louis Mo
    420
    C-4 we posted at the same time so I didn't benefit from your knowledge of the battery replacement procedure.
    Al.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Here's the skinny from Apple --
    Apple - Support - Battery Replacement Service - iPad
    "If your iPad requires service due to the battery's diminished ability to hold an electrical charge... Apple will replace your iPad for a service fee."
    Will the data on my iPad be preserved?
    No. You will receive a replacement iPad that will not contain any of your personal data. Before you submit your iPad for service, it is important to sync your iPad with iTunes to back up your contacts, calendars, email account settings, bookmarks, apps, etc. Apple is not responsible for the loss of information when servicing your iPad."
    4993
    3 times
    May 2010
    St.Louis Mo
    420
    Thats clear as mud. Tanks for that.
    Al
  1. Battery Replacement
    By Al Rogers in forum iPad General Discussions
    Last Post: 07-17-2010, 05:59 PM
  2. Getting a replacement tomorrow...
    By Max in forum iPad General Discussions
    Last Post: 04-14-2010, 06:45 PM
  3. Apple's iPad Battery Replacement Program
    By iDan in forum Apple iPad News
    Last Post: 03-15-2010, 11:17 AM
  4. Apple's iPad Battery Replacement Policy
    By wot_fan in forum iPad General Discussions
    Last Post: 03-14-2010, 08:43 AM
  5. Battery Replacement
    Last Post: 03-07-2010, 09:11 AM
does my i pad battery need replacing?
how can you tell if ipad2 battery needs replacing
how long before ipad battery needs to be replaced
how long before replacing ipad battery
how long do ipad batteries before replacement
how long does a battery last in i pad before replacing
how long does a ipad last before replacing it
how long does an ipad battery last before needing replaced
how long does an ipad battery last before replacement
how long does ipad battery last before replacement
how long will ipad battery last before replacement
howlong will i pad battery last before it must be replaced?
