Wi fi issues
This is a discussion on Wi fi issues within the iPad Help forums, part of the Apple iPad Discussions category; HELP PLEASE I have a 64gb3g iPad and ii am having problems with the wifi. Not a signal issue as this heppens when stood next ...
Results 1 to 6 of 6
Thread: Wi fi issues
    11630
    Aug 2010
    Chester, UK
    20
    Wi fi issues
    HELP PLEASE
    I have a 64gb3g iPad and ii am having problems with the wifi. Not a signal issue as this heppens when stood next to the router. I have a net gear router as supplied by my ISP. Sky. All my other devices including iPhone 4 and MacBook have no problems at all but my iPad will not always display the Internet etc when connected. Works all the time on 3G and sometimes on wifi but just as your getting into surfing the net it stops responding and safari is unable to connect.
    I have tried resetting the iPad. And router and even stopped the router from transmitting on 2 channels. I have ios 3.2.2 loaded on my iPad
    Could this be my iPad?
    Anyone else have the same issues?
    Thanks in advance for your help
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    Lots of threads on this in the forums if you look back. Most iPads work really well so the usual answer to your problem is interference which can be solved by switching channels. Theres a reason why you have them
    Just do a quick search.
    If you can test your iPad somewhere where there is free wifi (friends house, Starbucks etc.) you can at least eliminate it from your list of probable problems.
    GL
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Download a wifi scanning program to your laptop and see what is actually showing up in your house. Are you able to see a lot of neighbors wifi networks? If so you need to pick a wifi channel that is not being used by one of your neighbors. Its best to pic a channel as far away from others being used to eliminate interference.
    Just from a security stand point make sure your using WPA2 encryption.
    Also after making changes to your wireless router go into your ipad settings for the network and select the button that says "forget This network" and then connect to it again entering the correct key/password.
    11630
    Aug 2010
    Chester, UK
    20
    Worth a try i suppose. have already change the channel before but may need looking at again. didnt do the forget this network thing. Im sure it not my router as i say i have no troubles with the macbook or other windows based pc's or iphone. No issues with 3g either.
    i might try another wifi network and changing the channels again
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by Imspartacus View Post
    ipads wifi is much more sensitive to interference then most laptops.
    Also if you have any wireless house phones you may want to unplug the base stations and turn them off to see if that is whats causing the interference.
    11630
    Aug 2010
    Chester, UK
    20
    tHANKS FOR THAT. Changed the channel number, ipad forget the network, hidden the ssid and then found again ( manually) all logged on ok so far. fingers crossed.
  1. Connectivity issues
    By TheMitz in forum iPad Help
    Last Post: 04-09-2011, 10:24 AM
  2. Hotmail issues
    By Marla in forum iPad Help
    Last Post: 02-23-2011, 02:19 PM
  3. charging issues
    By dmanero in forum iPad Help
    Last Post: 07-07-2010, 07:07 PM
  4. Photo issues
    By MYGOGT in forum iPad Help
    Last Post: 06-30-2010, 09:37 AM
  5. How to Fix the iPad's Wi-Fi Issues
    By cimousa in forum iPad Help
    Last Post: 04-28-2010, 12:09 PM
channel change ipad
how to change wifi channel on ipad
ipad change channel for wifi
ipad interfere wireless
ipad interfere with wifi
ipad interference wifi
ipad interferes with wifi
ipad interfering wifi
ipad interfering wireless network
ipad interferring with wireless
ipad wifi channel
ipad wireless channel
Tags for this Thread
