Ipad 1 Restoring problems
This is a discussion on Ipad 1 Restoring problems within the iPad Help forums, part of the Apple iPad Discussions category; Hey, My dad just gave me his old iPad which doesn't work. It only shows the restore to iTunes logo. After trying to restore to ...
Results 1 to 3 of 3
    234612
    Aug 2012
    Hey, My dad just gave me his old iPad which doesn't work. It only shows the restore to iTunes logo. After trying to restore to 5.1.1 and that getting error 9 and 3194 I tried every other version of iOS for iPad 1 iOS 4 - 5.1.1. I'm doing this as I don't know what the 'current' iOS is. I've edited the host document so now apple doesn't appear in it. I've also tried restoring using DFU mode aswell just to see if that would do anything but nothing.
    I've managed to get to this screen [will edit this when I get 3 posts] When you restore you get the image of the apple logo with a loading bar under it. However this bar never fills and after 10 or so seconds it just reboots and loads the connect to itunes screen.
    I wonder if anyone on here can help as I've spent + 15 hours trying to sort it out. Also I know it's not the USB bus that isn't working as my iPhone 4 works perfectly fine. I've also taken it apart and checked all the connections and they're all perfectly fine (ie no bent connections)
    13576
    1444 times
    Aug 2010
    Western NY state (USA)
    11,049
    Try having a go with this tutorial: TUTORIAL - Failsafe method to restore the current version of IOS
    If you follow the steps exactly as written (and assuming you have no hardware faults), you should end up with an iPad running the most current iOS (5.1.1). Good luck and let us know how you get on.
    234612
    Aug 2012
    thanks for the quick reply but I've already used that guide and still nothing. I've posted on the apple forums as well and they just told me to use there out of warranty replacement service.
  1. Replies: 1
    Last Post: 06-30-2012, 10:02 PM
  2. After Restoring iPad 2 on New PC!
    By aztecaa in forum iPad 2 Forum
    Last Post: 04-09-2012, 05:43 PM
  3. Help with restoring my ipad 2.
    By NEOBAHAMUT in forum iPad Hacking
    Last Post: 11-10-2011, 01:58 PM
  4. Restoring your ipad
    By Royceanator in forum iPad Help
    Last Post: 08-30-2011, 04:43 AM
  5. ipad 3.2 not restoring 3.2.1
    By p3la in forum iPad Hacking
    Last Post: 08-07-2010, 01:18 PM
ipad 1 problems
ipad 1 restore issues
ipad restore problems
ipad1,1 restore
problems with ipad 1
restore ipad 1
restore ipad1
restoring ipad 1 problems
