I ipad2 is charging to 23% and not going any higher. Any ideas?
This is a discussion on Charging problems within the iPad Help forums, part of the Apple iPad Discussions category; I ipad2 is charging to 23% and not going any higher. Any ideas?...
Hmm, kind of unusual, assuming that you left it in sleep mode, are you using a proper charger accessory and are you charging through a socket that supplies enough juice?
"Utilize your day, make it as useful and fun as it can be."
If you like a post, give a second to press the like button, people work hard to supply you with information that you need, show them a little appreciation...
It's always handy reading this >>> Forum Rules <<<
--Allen Salar--
Yip been in sleep mode for a number of hours now but still not went up. And yea it's the proper cable and everything. Usually when the battery isn't full and u plug in the charger it comes up charging but mine comes up charged
That's very weird, I haven't encountered this before so I can't help much, I'm sorry.
But you can try to download ASUS Ai Charger in your Desktop or Laptop and try to charge your iPad from there, tell me how it works.
And I guess someone else will have to resolve this issue.
--Allen Salar--
Let the iPad run until it shuts down. Then try charging it again without interruption and using the charger and cable that came with it. It should take 4 to 6 hour for an iPad 2 if everything is working correctly.
Apple recommends that you do this about once a month in order to keep the percentage indicator calibrated. If it still does not work and your hardware warrantee still valid try contacting Apple.
https://selfsolve.apple.com/agreementWarrantyDynamic.do
Maybe it has something to do with the charger, I had an old iPad charger, it bent at the top where the plug was, and the charger couldn't charge because of it, so I had to replace the charger, because it was very difficult to get it to charge, it took me like 10 minutes each time to get it to charge, so I would suggest checking to see if there's anything strange about the charger.
Yea I've tried my friends charger and that worked fine, need to replace the charger
I'm glad I helpedOriginally Posted by Kaelib
Good advice, Amy!
ThanksOriginally Posted by skimonkey
