Problem upgrading to 3.2.2
This is a discussion on Problem upgrading to 3.2.2 within the iPad Help forums, part of the Apple iPad Discussions category; I'm trying to upgrade my iPad to 3.2.2. The backup process takes so long that my iPad loses all power before it finishes - my ...
Results 1 to 5 of 5
    5684
    Jun 2010
    France
    8
    I'm trying to upgrade my iPad to 3.2.2. The backup process takes so long that my iPad loses all power before it finishes - my USB connection cannot provide a charge. When I sync the iPad every day I abort the backup because of this, but I can see no way of doing this during the upgrade process. Does anyone know of a solution?
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    Use the 10 watt charger that came with your iPad and charge it to 100% before doing the upgrade.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    Quote Originally Posted by yigitusta View Post
    Don't upgrade to 3.2.2 it breaks all jailbreaksss
    DONTTT
    But how do you know this person has jailbroken their iPad?
    5684
    Jun 2010
    France
    8
    Yes, you're right - I have not jail broken, and I had to give up after 12 hours, by which time the battery was down to 25%. And that was after running the process to the point where the progress indication showed only about 5% had completed. What are the experiences of other upgraders?
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    If your battery level is going down even if you are plugged into your computer and if you are having trouble doing the backup, I suspect there might be a problem with the connection between your iPad and your computer.
    Even though your iPad shows "Not Charging" when it is plugged into your computer's USB port, it really is charging, but very slowly and your iPad definitely should not be losing battery power when plugged in.
    You might try doing a system reset by holding in the Home button at the bottom of the screen and the Sleep/Wake button on top at the same time until the Apple logo comes on the screen. Then you can let go and let your iPad start up normally. This seems to cure a lot strange problems! After that, then you can try to update.
  1. the Pros of upgrading to 3.2.1 (with JailbreakMe)
    By gouletjo in forum iPad Hacking
    Last Post: 08-10-2010, 08:14 PM
  2. Upgrading iTunes after jailbreak
    By Scmill in forum iPad Hacking
    Last Post: 06-16-2010, 08:55 PM
  3. Uk i pad wi fi problem
    By cultman1 in forum New Member Introductions - Site Assistance
    Last Post: 06-07-2010, 02:16 PM
  4. Upgrading from wifi to 3G
    By stefan@parhar.net in forum iPad General Discussions
    Last Post: 05-30-2010, 02:49 AM
  5. Sync Problem
    By Snapp in forum iPad Help
    Last Post: 05-27-2010, 08:23 PM
apple how to update ipad from 3.2 to 5.2
how long to upgrade ipad 3.2 to 5.1
pages for ipad 3.2
time it takes to update ipad from 3.2.2 to 5.1
upgrading 3.2.2 on ipad
upgrading an ipad without a backup
upgrading ipad 3.2.2
upgrading ipad 3.2.2 to 5.1
